Hi
I have an awful web app that is mainly legacy code I wrote many years back, but functions and the users use it all the time
WE're moving stuff around and at the moment the desktops are at a different site to the data so I'm hitting latency issues.
I have this code
dojo.forEach(dynamicMapServiceLayer.layerInfos, function (layer) {
var requestHandle = esri.request({
url: mapservice2 + "/" + layer.id + "?f=json",
handleAs: "json",
load: function (data) {
LayerAttach[layer.id] = data.hasAttachments;
console.debug(dynamicMapServiceLayer.layerInfos[layer.id])
LayerDescriptions[layer.id] = data.description;
dynamicMapServiceLayer.layerInfos[layer.id].copyrightText = data.copyrightText;
}, { useProxy: true });
Which I have on the Onload event of the main dynamic map It reads extra stuff from the rest data of the service that I use to create hyperlinks (as good old ArcIMS did)
All worked fine until this latency hit. I have a sub-site that on start up takes a feature passed in the URL, finds the extent of that feature, then passes that into a ID task on the main service. The output uses the arrays/data produced in the above routine. With the latency I am getting results of the ID task back before I get all the info from the above code.
I have vague knowledge of defers and the like so surely I should add to each loop above a wait until the data is back until stepping forward, or a wait until everything is back
Any advice welcomed.
In the short term I've given those users who use this sub-site Chrome, which can handle things faster and not get caught up.
Cheers
ACM
