Hi everyone,
I've been working on a web map and am having trouble zooming to the results of the FindTask. At some point, I'll also need to incorporate the functionality to zoom to a result if it's a single point, but first I'm just trying to get it to show results from a line and polygon layer! If someone could help out with my conundrum that would be lovely. Thank you!
<script>
// get the job number from the URL
var projNum = getUrlParameter('data').split("+")[0]; //this is a call to a function in a helper file
require([
"esri/map",
"esri/tasks/FindTask",
"esri/tasks/FindParameters",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/Color",
"dojo/on",
"dojo/dom",
"dijit/registry",
"dojo/_base/array",
"dojo/_base/connect",
"dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
Color, on, dom, registry, arrayUtils, connect, parser
var findTask, findParams;
var map, center, zoom;
parser.parse();
map = new esri.Map("map", {
basemap: "streets",
center: [-122.8, 49.2],
zoom: 10
//Create Find Task using the URL of the map service to search
findTask = new FindTask("URL HERE");
map.on("load", function () {
//Create the find parameters
findParams = new FindParameters();
findParams.returnGeometry = true;
findParams.layerIds = [0,1,2];
findParams.searchFields = ["Project_Number"];
findParams.outSpatialReference = map.spatialReference;
console.log("find sr: ", findParams.outSpatialReference);
//Set the search text to the value in the box
findParams.searchText = projNum;
findTask.execute(findParams, showResults);
function showResults(results) {
//This function works with an array of FindResult that the task returns
map.graphics.clear();
//SYMBOLOGY FOR GRAPHICS
//polygon
var polygonSymbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 1),
new Color([98, 194, 204, 0.5])
//line
var lineSymbol = new SimpleLineSymbol();
//SimpleLineSymbol.STYLE_SOLID;
lineSymbol.setWidth(3);
lineSymbol.setColor(new Color([0,230,169,1]));
//point
var markerSymbol = new SimpleMarkerSymbol();
markerSymbol.setSize(12);
markerSymbol.setColor(new Color([0,230,169,1]));
//create array of attributes
var items = arrayUtils.map(results, function (result) {
var graphic = result.feature;
switch (graphic.geometry.type) {
case "point":
graphic.setSymbol(markerSymbol);
break;
case "polyline":
graphic.setSymbol(lineSymbol);
break;
case "polygon":
graphic.setSymbol(polygonSymbol);
break;
map.graphics.add(graphic);
return result.feature;
var myFeatureExtent = graphicsUtils.graphicsExtent(items);
map.setExtent(myFeatureExtent, true);
</script>
