Get selected single point geometry, use in map.centerAndZoom
2923
10-06-2015 12:27 AM
DavidChrest
Occasional Contributor II
I can easily zoom to a selection of points in my FeatureLayer with this handy one-liner:
map.setExtent(graphicsUtils.graphicsExtent(myFeatureLayer.getSelectedFeatures()), true);
In this case, it's assigned to a button.
How do I utilize the map.centerAndZoom when just a single point of my Feature Layer is selected?
Just want to assign to a different button. I can't seem to find the exact syntax but I know I need to grab the geometry of the single selected point to then use in map.centerAndZoom.
Thnks so much. Any help is greatly appreciated.
David
RobertScheitlin__GISP
David,
So it would look more like this then:
var gExt = graphicsUtils.graphicsExtent(myFeatureLayher.getSelectedFeatures());
if (gExt) {
  map.setExtent(gExt.expand(1.5), true);
} else {
  var mp2 = myFeatureLayher.getSelectedFeatures()[0].geometry;
  map.centerAndZoom(mp2, 17);
David,
  Here is some code I use:
if (gExt) {
} else {
  var mp2 = currentLayerAdded.graphics[0].geometry;
  map.centerAndZoom(mp2, 12);
DavidChrest
Finally figured out how to insert code nicely to my replies. Here is my quick and dirty zoom and center fix for a single selected feature:
on(dom.byId("zoomToSelectedPoint"), "click", function () {
  centermap();
  setTimeout(function () {
  zoomin17();
  }, 500);
  function centermap() {
  map.setExtent(graphicsUtils.graphicsExtent(activitiesDay1.getSelectedFeatures()), true);
  function zoomin17() {
  map.setZoom(17);
David,
if (gExt) {
} else {
DavidChrest
Here is my code I came up with for a zoom button that works nicely. Works if multiple points or a single point is selected.
on(dom.byId("zoomToSelectedD1Activities"), "click", function () {
  var countp = activitiesDay1.getSelectedFeatures().length;
  if (countp > 1) {
  } else {
  var mp1A = activitiesDay1.getSelectedFeatures()[0].geometry;
  map.centerAndZoom(mp1A, 18);
DavidChrest
Aha! That's it. Thanks so much, Robert. I was trying this last night but had forgotten the "()" between "getSelectedFeatures" and "[0]." Silly me. That's what happens when you stay up 'til 3:00 AM coding.
