Saroj,
You can handle this from the database level or service level.
Database Level: Update the alias field names in the feature class directly from ArcCatalog. For this you simply need to stop the map services for few minutes and open the feature class properties and update the alias field names available under the Field tab. You will have to re-add the layers in the map document and overwrite the existing map service.
Service level:- Provide alias fields names to each layer in the map document and overwrite the map service. This can be achieved by going into each layer's layer properties and Field tab. However, this has few drawbacks though, like if the same layer has been added over multiple times, you will have to update the alias field names multiple times and if the field names change in the database it will not reflect in the map document unless the layer has been added freshly.
Refer Modifying field properties—ArcGIS Help | ArcGIS Desktop
I hope this helps!
-Shan
~Shan
