Here is the code I'm using for the default.html (which works when I open it in chrome, just fails when I hit F5 to debug in VS using Local Machine)
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title></title>
<link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
#map {
padding: 0;
</style>
<script src="http://js.arcgis.com/3.14/"></script>
<script>
var map;
require([
"esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
"dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
"dojo/domReady!"
], function (
Map, BasemapGallery, arcgisUtils,
parser
parser.parse();
map = new Map("map", {
basemap: "topo",
center: [-105.255, 40.022],
zoom: 13
//add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function (msg) {
console.log("basemap gallery error: ", msg);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:false"
style="width:100%;height:100%;margin:0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'"
style="padding:0;">
<div style="position:absolute; right:20px; top:10px; z-Index:999;">
<div data-dojo-type="dijit/TitlePane"
data-dojo-props="title:'Switch Basemap', closable:false, open:false">
<div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
<div id="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
