Getting started using Visual Studio - require is undefined
4064
6
07-17-2015 02:09 PM
DavidChevrier
Occasional Contributor II
     I'm transitioning from the silverlight api to the the javascript api.  (Reluctantly, because I really enjoy programming in C and using MVVM and XAML, way less developer plug-ins needed and easier to debug, but I digress.)  I grabbed a simple sample javascript api html file from esri's site and when I open it in chrome, it works no problem.  Then I tried to make this in Visual Studio 2013 (which is what I want to use as my IDE).
I first added in the plug-ins listed on the esri site and created a new project with the template javascript-->Store Apps-->Windows Apps-->Blank App.  I copied the html over to the default.html, but when I ran it (F5), it says "JavaScript runtime error: 'require' is undefined".  I looked around the forums but the only solution listed (changing the source in the script tag from .../3.14 to .../3.14/init.js) did not work.  Since I know the html works in a browser, how do I get Visual Studio to work with this api?  And what template should I use for a proper website, there aren't many listed for javascript?
Thanks
JoelBennett
MVP Regular Contributor
I created a new website in Visual Studio 2010, then added an HTML page via Add New Item.  I pasted your code in there, ran the debugger and the page loads fine.
I opened the network tab on the developer tools window (F12) and noticed that when the browser requested
http://js.arcgis.com/3.14/
the server replied with a 302 and redirected to
http://js.arcgis.com/3.14/init.js
Maybe try that full URL as the src for your script tag.
thejuskambi
Occasional Contributor III
The error occurs when a amd module is being loaded before the esri init file is loaded.
Check all your js files references/scripts tags. make sure the arcgis api is first loaded and if there is a script for dojoConfig. It should be before the esri api tag.
ChrisSergent
Regular Contributor III
Can you share your code on JS Bin - Collaborative JavaScript Debugging  or do you have your project on GitHub. Not sure why it's working in the browser. Did you already check developer tools. In Google Chrome you can just press F12. I develop pure HTML5 and .NET with Visual Studio 2013 Professional so I will do what I can to help you.
I am not sure what plug-ins you needed unless it was not web related as I develop strictly web apps and I have not needed any unless you mean JsLint.
DavidChevrier
  What template do you use when you start a new project in VS?  For plug-ins, I installed typescript, the arcgis-js-api-typescript and dojo using nuget.  In the extensions, I added JSLint.Net for VS, VS Extensions for Window Library for JavaScript, and Web Essentials 2013 update 4.
DavidChevrier
Here is the code I'm using for the default.html (which works when I open it in chrome, just fails when I hit F5 to debug in VS using Local Machine)
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title></title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
        html, body {
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0;
        #map {
            padding: 0;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        var map;
        require([
          "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
          "dojo/parser",
          "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
          "dojo/domReady!"
        ], function (
          Map, BasemapGallery, arcgisUtils,
          parser
            parser.parse();
            map = new Map("map", {
                basemap: "topo",
                center: [-105.255, 40.022],
                zoom: 13
            //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
            var basemapGallery = new BasemapGallery({
                showArcGISBasemaps: true,
                map: map
            }, "basemapGallery");
            basemapGallery.startup();
            basemapGallery.on("error", function (msg) {
                console.log("basemap gallery error:  ", msg);
    </script>
</head>
<body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;margin:0;">
        <div id="map"
             data-dojo-type="dijit/layout/ContentPane"
             data-dojo-props="region:'center'"
             style="padding:0;">
            <div style="position:absolute; right:20px; top:10px; z-Index:999;">
                <div data-dojo-type="dijit/TitlePane"
                     data-dojo-props="title:'Switch Basemap', closable:false, open:false">
                    <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
                        <div id="basemapGallery"></div>
                    </div>
                </div>
            </div>
        </div>
    </div>
</body>
</html>
JoelBennett
DavidChevrier
Thanks!  Creating a new website (of type ASP.NET Empty Web Site in Visual C#), then adding new item-->html page did it!  I was creating a project with the template for javascript-->store apps-->Blank App.  It probably adds a bunch of extra stuff I don't need that causes the error.
