Having Issue On Removing Layer on ArcGIS API For JavaScript
2922
09-15-2015 06:47 PM
BruceGreen
New Contributor III
I am adding a markers layer called `layer1` like this to map
 function drawPoints(mapInfo) {
      layer1 = new esri.layers.GraphicsLayer();
        for (var i = 0; i < mapInfo.length; i++) {
               var projects = mapInfo;
               var project = new esri.geometry.Point(projects.Longitude, projects.Latitude);
               project = esri.geometry.geographicToWebMercator(project);
               var symbol = new esri.symbol.PictureMarkerSymbol("img/map/marker.png", 18, 18);
               projectInfoTemplate = new InfoTemplate();
               projectInfoTemplate.setTitle("Project Details");
               projectInfoTemplate.setContent('<div class="row"></div> ');
               var projectsG = new esri.Graphic(project, symbol).setInfoTemplate(projectInfoTemplate);
               layer1.add(projectsG);
              map.addLayer(layer1);
now in next request I need to clear map so I used the
    map.removeLayer(layer1);
but this is causing error because the `layer1` still not created at first request. Now I need to check `IF` the map has a layer called `layer1` then removeit. Here is a pseudo code of what I need to do:
    if(map.has/contains/include(layer1){
can you please let me know how to do that?
Tags (1)
TyroneBiggums
Occasional Contributor III
Make sure that your business rules and conditions are referencing the same data. If you are checking for map.getLayer by id then removing an instance of an object, you might get unexpected results.
Try:
var layer = map.getLayer(id);
if (layer) { map.removeLayer(layer); }
RobertScheitlin__GISP
Behrouz,
  Just do this (line 3 and 18 thru 20):
  layer1.id = "MyGL";
if(map.getLayer("MyGL")){
TyroneBiggums
Try:
RakeshModi
you can use
map.removeLayer(map.getLayer(map.graphicsLayerIds[/*index of your graphical layer*/]));
