How do I add a shapefile (.lpk) to a map?
3340
7
11-22-2013 03:07 PM
DamNguyen
I'm not familiar with GIS so I don't know what kind of layer a shapefile is. How do I add it to an existing map?
My map:
map = new esri.Map("mapDiv", {
    center: [-95.80, 39.29],
    zoom: 4,
    basemap: "topo"
Thank you.
JianHuang
When you say "add to map", is that map only for you displaying on your computer? Or, do you want to pass the URL of the web app so that you can share it?
In order to share your data or layer, you have to host it as a service either on your ArcGIS Server machine, or put it on arcgis.com.
DamNguyen
Hi Jian,
I want the map to be share-able on a public website. Since I don't have my own ArcGIS server, how would I put it on arcgis.com? And what kind of layer class/object does shapefile fall under? I'm not sure if I phrased this question correction. As an example, to add a KML layer, I would create a KMLLayer object then add it to the map by doing so:
dojo.require("esri.layers.KMLLayer");
var kmlUrl = "http://url-to-kml-file-here.kmz";
kml1 = new esri.layers.KMLLayer(kmlUrl);
map.addLayer(kml1);
But for a shapefile (.lkp), what do I do?
Again, thanks for your help.
JeffPace
MVP Alum
you can't add shapefiles.  Otherwise few would pay for Server.
You have to either publish the data, or publish it on arcgis.com with an account and then consume the webmap in your application.
DamNguyen
Hi Jeff,
I'm not understanding you entirely because I'm very new at this. Sorry in advance. By publish it on arcgis.com. Do you mean create a webmap (http://www.arcgis.com/home/webmap/viewer.html) upload the shapefile, then embed it in my website?
JeffPace
MVP Alum
Yes
http://resources.arcgis.com/en/help/arcgisonline/index.html#//010q000000m2000000
But remember
Limitations
Below are the limitations to using shapefiles in the ArcGIS.com map viewer.
Compression formats other than a .zip archive are not supported.
Files containing more than 1,000 features cannot be added to a map.
The following features are not supported: multipatch or multipoint geometries, geometries that cross the dateline, or self-intersections in polygons. Shapefiles with these features cannot be added to a map.
If your shapefile is outside this it won't work for you.
DamNguyen
Thank you, Jeff!
JeffPace
MVP Alum
you are welcome.  good luck
