How Do I Identify The Name of a Layer ID
849
01-23-2012 01:06 PM
ChrisSergent
Regular Contributor III
I want to evaluate the name of a layer like I did in the Web ADF, but I can't seem to find code similar to that?
Here is a URL with a screen recording of my question:
http://youtu.be/WkR4VBjx2_s
Thanks again.
Chris S.
derekswingley1
If you're setting up a query task against a layer that's in a map service you've already added to your JS API map, you can use the map service's layerInfos to loop through and match a name to an id.
Otherwise, use esri.request() to make a call to your map service endpoint. The JSON that comes back will have a layers property. Layers is an array of objects where each object corresponds to a layer in the map service. Every layer object will have an id and a name.
And thank you for the video- wish more people would do that :).
derekswingley1
ChrisSergent
Thanks Derek. This works.
Here is a line of code with my alert: alert(dynamicMapServiceLayer.layerInfos[4].name);
I have found videos to save time in explaining. 😄
derekswingley1
Indeed they do!
Glad I could help.
