Could either of you describe in more detail which section of the Draw widget code, and which file, that you need to edit the default fill? I'm specifically looking to have our default polygon draw with a 45 deg line hatch and a 2 pt. outline for example, however I'm looking through the Widget.js file and am having a little trouble connecting the dots from the links above as to how/where to alter the widget code, thanks!
