How to change the default color of the draw widget?
3533
10
07-05-2016 07:45 AM
HuyVo1
New Contributor II
Hello everyone,
is there somewhere in the code that can change the default color of the draw widget from black to ,say , red?
HuyVo1
New Contributor II
Thank you very much !
RobertScheitlin__GISP
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
HuyVo1
New Contributor II
I accidentally marked my answer as correct answer. I'm looking for a way to resolve it. Is there anyway to fix this problem?
Huy,
  Sure just open this thread (you can not do this from your inbox) and click on the Correct Answer link on the appropriate reply.
MichaelAugust
Occasional Contributor III
Could either of you describe in more detail which section of the Draw widget code, and which file, that you need to edit the default fill? I'm specifically looking to have our default polygon draw with a 45 deg line hatch and a 2 pt. outline for example, however I'm looking through the Widget.js file and am having a little trouble connecting the dots from the links above as to how/where to alter the widget code, thanks!
Michael,
   In the DrawWidget/Widget.js file find the postCreate function (line 6):
      postCreate: function() {
        this.inherited(arguments);
        this._initLayers();
        jimuUtils.combineRadioCheckBoxWithLabel(this.showMeasure, this.showMeasureLabel);
        this.drawBox.setMap(this.map);
        this.drawBox.setPolygonSymbol(yoursymbol);
MichaelAugust
Thanks Robert, I'll check that out!
by Anonymous User
Not applicable
I'm just stumbling across this thread, but I also want to change the default polygon color in the Draw widget. I'm not getting how to do this through the line of code inserted on line 6 above. I've experimented and tried inserting all kinds of parameters but I'm obviously not getting it.  All I want to do is change the default polygon color to red with a black outline. Can someone help me implement this? Thanks.
