There isn't native support for this in the SDK since polygon graphics only support horizontal labeling (see the LabelClass.labelPlacement property). That's not to say you can't pull this off with a little extra work though. One idea would be to maintain a separate polyline layer where the polygons have been converted to polylines, and those polylines labeled instead, since the SDK does support drawing labels alone lines. If you make those polylines transparent, it will appear as if the polygon edge is labeled.
Below is a basic example:
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Sketch widget | Sample | ArcGIS Maps SDK for JavaScript 4.28</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.28/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.28/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Color",
"esri/Graphic",
"esri/Map",
"esri/geometry/Polygon",
"esri/geometry/Polyline",
"esri/layers/FeatureLayer",
"esri/renderers/SimpleRenderer",
"esri/symbols/Font",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/TextSymbol",
"esri/views/MapView"
Color,
Graphic,
Map,
Polygon,
Polyline,
FeatureLayer,
SimpleRenderer,
Font,
SimpleFillSymbol,
SimpleLineSymbol,
TextSymbol,
MapView
const map = new Map({
basemap: "topo-vector"
const view = new MapView({
container: "viewDiv",
map: map,
zoom: 5,
center: [90, 45]
view.when(() => {
var polygon = Polygon.fromJSON({
spatialReference: { latestWkid: 3857, wkid: 102100 },
rings: [
[9201708.294980831, 6103380.512501691],
[9199505.916630479, 6061356.630160495],
[9192922.9112975, 6019793.170268292],
[9182031.40376591, 5979145.510789373],
[9166950.723671414, 5939858.9959870605],
[9147846.098100968, 5902364.05713876],
[9124926.841330219, 5867071.496640812],
[9098444.06153251, 5834367.987171478],
[9068687.909585183, 5804611.835224151],
[9035984.400115848, 5778129.055426442],
[9000691.8396179, 5755209.7986556925],
[8963196.9007696, 5736105.173085245],
[8923910.385967288, 5721024.492990751],
[8883262.726488369, 5710132.98545916],
[8841699.266596166, 5703549.980126182],
[8799675.38425497, 5701347.601775828],
[8757651.501913773, 5703549.980126182],
[8716088.04202157, 5710132.98545916],
[8675440.382542651, 5721024.492990751],
[8636153.867740339, 5736105.173085245],
[8598658.928892039, 5755209.7986556925],
[8563366.368394092, 5778129.055426442],
[8530662.858924756, 5804611.835224151],
[8500906.70697743, 5834367.987171478],
[8474423.92717972, 5867071.496640812],
[8451504.670408972, 5902364.057138759],
[8432400.044838525, 5939858.9959870605],
[8417319.36474403, 5979145.510789373],
[8406427.85721244, 6019793.170268291],
[8399844.85187946, 6061356.630160495],
[8397642.473529108, 6103380.512501691],
[8399844.85187946, 6145404.394842886],
[8406427.85721244, 6186967.8547350895],
[8417319.36474403, 6227615.514214008],
[8432400.044838525, 6266902.029016321],
[8451504.670408972, 6304396.967864621],
[8474423.92717972, 6339689.5283625685],
[8500906.706977429, 6372393.037831903],
[8530662.858924756, 6402149.18977923],
[8563366.368394092, 6428631.969576939],
[8598658.928892039, 6451551.226347689],
[8636153.867740339, 6470655.851918136],
[8675440.382542651, 6485736.53201263],
[8716088.04202157, 6496628.039544221],
[8757651.501913773, 6503211.044877199],
[8799675.38425497, 6505413.423227553],
[8841699.266596166, 6503211.044877199],
[8883262.726488369, 6496628.039544221],
[8923910.385967286, 6485736.53201263],
[8963196.900769599, 6470655.851918136],
[9000691.8396179, 6451551.226347689],
[9035984.400115848, 6428631.96957694],
[9068687.909585183, 6402149.18977923],
[9098444.061532509, 6372393.037831904],
[9124926.841330219, 6339689.528362569],
[9147846.098100968, 6304396.967864622],
[9166950.723671414, 6266902.029016321],
[9182031.40376591, 6227615.514214008],
[9192922.9112975, 6186967.85473509],
[9199505.916630479, 6145404.394842887],
var polygonGraphic = new Graphic({
geometry: polygon,
symbol: new SimpleFillSymbol({
color: new Color([192, 192, 192, 0.5]),
outline: new SimpleLineSymbol({
color: new Color([255, 0, 0, 1]),
style: "solid",
width: "2px"
style: "solid"
view.graphics.add(polygonGraphic);
var polylineJson = polygon.toJSON();
polylineJson.paths = polylineJson.rings;
delete polylineJson.rings;
var polyline = Polyline.fromJSON(polylineJson);
var polylineGraphic = new Graphic({
geometry: polyline,
attributes: { OBJECTID: 1, LABELFIELD: "My Label Text" }
var layer = new FeatureLayer({
source: [polylineGraphic],
objectIdField: "OBJECTID",
fields: [
type: "oid"
type: "string"
renderer: new SimpleRenderer({
symbol: new SimpleLineSymbol({
color: new Color([0, 0, 0, 0]),
style: "solid",
width: "2px"
labelingInfo: [
labelExpressionInfo: { expression: "$feature.LABELFIELD" },
labelPlacement: "center-along",
repeatLabel: false,
symbol: new TextSymbol({
color: new Color([255, 255, 255, 1]),
font: new Font({
family: "Arial",
style: "normal",
weight: "bold"
haloColor: new Color([0, 0, 0, 1]),
haloSize: 2
view.map.add(layer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
