Yes, I get that the main geometry is a Point. However, no matter how I zoom the map in or out, edit the TextSymbol by making it smaller/larger, or even rotate it to any angle, the 'mouse-over' still fires exactly perfectly with the shape/size/orientation of the text. So it seems that the map must somehow be holding this exact geometry to be able to tell if your mouse pointer is inside it, right?
