i was tested to the IdentyfyTask.
But I could not get a response before the value addCallback.
i want to the pnu values.
But pnu vaule was alwayes undefined...
my code is follows.
function poiClick(){
agmap.addEvent("click", function(evt){
getPoi= krcgis.Function.PoiClick(agmap ,evt);
console.log("X === ",getPoi.x);
console.log("Y === ",getPoi.y);
console.log("PNU === ",getPoi.pnu);
PoiClick : function(map, evt) {
poiInfo = {};
poiInfo.x =evt.mapPoint.x;
poiInfo.y =evt.mapPoint.y;
var targetLayerId = 'LP_PA_CBND';
var url = map.Layers.getLayerInfo(targetLayerId).SVC_URL;
var map = map.getMap();
//파라미터 설정.
var idParams = new krcgis.core.tasks.IdentifyParameters();
idParams.geometry = evt.mapPoint;
idParams.mapExtent = map.extent;
idParams.returnGeometry = true;
idParams.tolerance = 0;
idParams.layerOption = krcgis.core.tasks.IdentifyParameters.LAYER_OPTION_ALL;
idParams.width = map.width;
idParams.height = map.height;
idTask = new krcgis.core.tasks.IdentyfyTask(url);
idTask
.execute(idParams)
.addCallback(function (response) {
if (response) {
poiInfo.pnu =response[0].value;
return poiInfo;
The results were as follows.
