How to hide the popup that appeared at 3.17?
2732
7
06-27-2016 02:38 AM
JonathanDoig1
I've been developing a web app on ArcGIS for JS 3.16. I just noticed that 3.17 has been released so I tried loading that instead of 3.16. It seems to work fine except that the bottom edge of a popup window is now visible on map load. I don't use popups in my app at all.
Why is it appearing and how should I hide it? I tried map.infoWindow.hide() to no avail. I guess I could fiddle with the CSS but I'm more inclined to simply revert to 3.16.
Top left corner with v3.16:
Top left corner with v3.17 (with the element "inspected" in Chrome Developer Tools):
Here are the functions I load - do I need to set an option to disable popups on one of these?
  require([
        "esri/map",
        "esri/dijit/HomeButton",
        "esri/layers/FeatureLayer",
        "esri/geometry/Extent",
        "esri/geometry/Point",
        "esri/symbols/TextSymbol",
        "esri/symbols/Font",
        "esri/layers/LabelClass",
        "esri/Color",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/renderers/SimpleRenderer",
        "esri/symbols/SimpleFillSymbol",
        "esri/tasks/query",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/LocateButton",
        "esri/tasks/locator",
        "dojo/domReady!"
RobertScheitlin__GISP
Jonathan,
  I am not seeing that in any of the 3.17 samples. Can you post your full code that is exhibiting this behavior?
RyanWever
Hi Jonathan,
I'm experiencing the same problem. Did you happen to figure out how to fix it?
Ryan,
  You should post your code as almost no one else is having this issue. As you can see Jonathan did not bother to post back likely because he found his mistake in his code.
RyanWever
Hi Robert,
I am able to reproduce my issue with the following code:
define([
    "dojo/parser", "dojo/ready", "dojo/dom",
    "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
    "esri/map", "esri/urlUtils", "esri/arcgis/utils",
    "dojo/domReady!"
], function (
    parser, ready, dom,
    BorderContainer, ContentPane,
    Map, urlUtils, arcgisUtils
    function drawMap() {
                //render map
                return ready(function () {
                    parser.parse();
                    arcgisUtils.arcgisUrl = myUrl;
                        return arcgisUtils.createMap(myWebMapId, "map");
    drawMap();
Please let me know if I can provide any further information.
Ryan,
   Yes I need to see your whole html code to inspect your css and script blocks
RyanWever
Aha, it was an issue with CSS. I had updated my Javascript files but not the CSS.
Thanks for responding so quickly!
JonathanDoig1
Aah thanks for the update Ryan. I suspect that I also overlooked updating my CSS link. Should be:
  <link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
At the time I just reverted the JS link to 3.16. Sorry I missed your earlier response Robert Scheitlin, GISP
