How to implement functionality similar to "saving file in .mxd format" in web application using arcgis api for javascript?
4232
12
07-15-2014 02:54 AM
GauriDeshmukh
New Contributor III
I need to implement a functionality which will save all layers added to map,its all display information like current extent, symbology and queried features if any etc. Its similar to saving an mxd(map document) file in arc map. But I want save this layer details in a table in database. When a user will open this saved file the layer should get added to map with all its saved properties.
nicogis
MVP Frequent Contributor
You can have a similar functionality using the webmap format.
See this sample: Web map using JSON | ArcGIS API for JavaScript
Help format web map json: ArcGIS web map JSON format
GauriDeshmukh
New Contributor III
Hello Domenico Ciavarella
I am still not clear how to store the current json data or layer information of map.I want to save it but not getting how?
As per this sample I got the direction, it is about creating web map from json data.
nicogis
Gauri Deshmukh‌, I don't think that there is an out of box for serialize in webmap. You can see sample project how this for serialize : swingley/cereal · GitHub
GauriDeshmukh
New Contributor III
ciava.at  excellent ..using the code for map-cereal.js from  swingley/cereal · GitHub‌, I am able to get JSON response for my current map document and can create Webmap from this json.
GauriDeshmukh
New Contributor III
Now I am looking for converting this webmap to map or is there any way to construct a map again with the json response.
KevinDeege
HI Gauri, this sample illustrates how to get a map from the web map response:
The key aspect of the sample is using the arcgisUtils class to create a deferred object, then obtain the map from the response.
arcgisUtils.createMap(webmap,"map").then(function(response){
var map = response.map;
//do something with the map here
GauriDeshmukh
New Contributor III
Hey KDeege-esristaff ,
I dont want to create web map  or a map like this, I want to add the layers which i got in response ,separately  to the map by map.addddLayer method (as per my requirement).
GauriDeshmukh
New Contributor III
How do I add layer in the form of object to map.
KevinDeege
Can you use the array of layers in the response as a way to accomplish this?
                var layers = response.itemInfo.itemData.operationalLayers;
