how to logout from portal
1786
09-14-2021 01:35 AM
Arpa_PiemonteGeoportal_Team
Occasional Contributor II
I can log in into my portal, but I cannot log out.
The log in starts after click a bottom.
This is my code (from https://developers.arcgis.com/javascript/latest/api-reference/esri-portal-Portal.html#methods-summar...😞
// load the Portal and PortalQueryParams modules
require(["esri/portal/Portal",
 "esri/portal/PortalQueryParams"
], function(Portal, PortalQueryParams) {
  portal = new Portal();
  // Setting authMode to immediate signs the user in once loaded
  portal.authMode = "immediate";
  // Once portal is loaded, user signed in
  portal.load().then(function() {
    console.log(portal);
    // Create query parameters for the portal search
    // This object autocasts as new PortalQueryParams()
    let queryParams = {
      query: "owner:" + portal.user.username,
      sortField: "numViews",
      sortOrder: "desc",
      num: 20
    // Query the items based on the queryParams created from portal above
    portal.queryItems(queryParams).then(createGallery);
 Then the login windows is opened:
And all works fine, I insert my credential and I can work with it.
 Then I want to log out to consent to other users to login, but I can't find in the documentation the way.
I tried:
    portal.user = null
    portal.cancelLoad()
    portal = false
    delete portal;
But if I click the login bottom, the login windows doesn't appear and the old user is already connected!
Thanks
ReneRubalcava
Portal load kicks in the IdentityManager authentication workflow. So you can use the IdentityManager destroyCredentials() method to sign out.
https://developers.arcgis.com/javascript/latest/api-reference/esri-identity-IdentityManager.html#des...
ReneRubalcava
Yes, thanks, this works for me:
IdentityManager.destroyCredentials();
