how to put a ArcGISDynamicMapServiceLayer on top of a GraphicsLayer
2722
10-27-2015 02:04 PM
davidzornosa
New Contributor III
i have:
1 - a polygon drawn in a GraphicsLayer.
2 - a set of points contained in the polygon. These points are stored in a ArcGISDynamicMapServiceLayer
The idea is to display the graphicsLayer in the back and the dynamicLayer in the front. However, arcgis always displays the layers in the inverse order (graphicslayer in the front and dynamicLayer in the back).
I've tried:
- getDojoShape().moveToBack()
- map.reorderLayer
to no avail.
Thanks
KenBuja
MVP Esteemed Contributor
This cannot be done in 3.x, but it will be possible in 4.x. A GraphicsLayer will always be in front of a Tiled or Dynamic layer. From the help
Also, all graphics layers are always on top of TiledMapServiceLayers and DynamicMapServiceLayers.
One way around this would be to use a FeatureLayer instead of a Dynamic Layer, since the FeatureLayer displays data via a GraphicsLayer.
KenBuja
