I am building a web application that uses ArcGIS Identity to authenticate the user and ideally provide access to a private embedded ArcGIS Dashboard without requiring additional sign in. I am able to set up the authentication and parse the token.
What I have not found is how to properly use the token to allow access to the ArcGIS Dashboard embedded in a portion of the application. I have not found anything in the documentation but have tried as the source of the iFrame src="<dashboard-url>?token=<token>" or src="<dashboard-url>?code=<token>" but both still show the pop-up asking for the user to sign again.
Is this possible? Or is there a better way to go about this?
