below example works without error, but if i change the service to https from http then the error is appeared as some certification error(image below)
added proxy.ashx, proxy.config but still getting same certification error.
can we handle this in code or is it something related to server?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>FeatureLayer</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
<script src="https://js.arcgis.com/3.27/"></script>
<style>
html, body, #map {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/map",
"esri/layers/FeatureLayer",
"dojo/domReady!"
function(
Map,
FeatureLayer
var map = new Map("map", {
basemap: "hybrid",
center: [122.3321, 47.6062],
zoom: 12
var featureLayer = new FeatureLayer("http://aaaaa.bbbbb.com/arcgis/rest/services/Maps/CityMap/MapServer/1");
map.addLayer(featureLayer);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
