Hurricane Path on ESRI Map
1895
07-10-2014 03:13 AM
SrimathiSekar
Hi,I have requirement of implementing the hurricane path over the esri map. this esri map is integrated with MicroStrategy. The map is plotted with geocodes and it also has the hurricane. But this hurricane overrides the markers which are plotted and i am not able to do any selection on the map. We are using arcgis java script 2.4 comes in built with MicroStrategy 9.4.1 Hf3. By Tweaking on the same js files we tried to implement the hurricane. Any body has any idea to overcome on this. please let us know
