James,
Here is the sample modified to have all results in the popup without paging (not sure about the only highlighting layer 0):
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Identify Task - 4.1</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-popup .esri-popup-header .esri-title {
font-size: 18px;
font-weight: bolder;
.esri-popup .esri-popup-body .esri-popup-content {
font-size: 14px;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
<script src="https://js.arcgis.com/4.1/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/TileLayer",
"esri/tasks/IdentifyTask",
"esri/tasks/support/IdentifyParameters",
"dojo/_base/array",
"dojo/on",
"dojo/dom",
"dojo/domReady!"
], function(
Map, MapView, TileLayer,
IdentifyTask, IdentifyParameters,
arrayUtils, on, dom
var identifyTask, params;
var soilURL =
"https://services.arcgisonline.com/arcgis/rest/services/Specialty/Soil_Survey_Map/MapServer";
var parcelsLyr = new TileLayer({
url: soilURL,
opacity: 0.85
var map = new Map({
basemap: "osm"
map.add(parcelsLyr);
var view = new MapView({
map: map,
container: "viewDiv",
center: [-120.174, 47.255],
zoom: 7
view.then(function() {
on(view, "click", executeIdentifyTask);
identifyTask = new IdentifyTask(soilURL);
params = new IdentifyParameters();
params.tolerance = 3;
params.layerIds = [0, 1, 2];
params.layerOption = "top";
params.width = view.width;
params.height = view.height;
function executeIdentifyTask(event) {
params.geometry = event.mapPoint;
params.mapExtent = view.extent;
dom.byId("viewDiv").style.cursor = "wait";
identifyTask.execute(params).then(function(response) {
var results = response.results;
var retVal = {};
var rsltContent = arrayUtils.map(results, function(result) {
var contentString;
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerName;
if (layerName === 'Soil Survey Geographic') {
contentString = "<h3>" + feature.attributes["Map Unit Name"] + "</h3><strong>Dominant order:</strong> " + feature.attributes["Dominant Order"] + " (" + feature.attributes["Dom. Cond. Order %"] + "%)" + "<br><strong>Dominant sub-order:</strong> " + feature.attributes["Dominant Sub-Order"] + " (" + feature.attributes["Dom. Cond. Suborder %"] + "%)<br><strong>Dominant Drainage Class:</strong> " +
feature.attributes["Dom. Cond. Drainage Class"] + " (" + feature.attributes["Dom. Cond. Drainage Class %"] + "%)" + "<br><strong>Farmland Class:</strong> " + feature.attributes["Farmland Class"];
else if (layerName === 'State Soil Geographic') {
contentString = "<h3>" + feature.attributes["Map Unit Name"] + "</h3><strong>Dominant order:</strong> " + feature.attributes["Dominant Order"] + " (" + feature.attributes["Dominant %"] + "%)" + "<br><strong>Dominant sub-order:</strong> " + feature.attributes["Dominant Sub-Order"] + " (" + feature.attributes["Dominant Sub-Order %"] + "%)";
else if (layerName === 'Global Soil Regions') {
contentString = "<h3>" + layerName + "</h3><strong>Dominant order:</strong> " + feature.attributes["Dominant Order"] + "<br><strong>Dominant sub-order:</strong> " + feature.attributes["Dominant Sub-Order"];
return contentString;
}).join("<br><br>");
retVal.content = rsltContent;
retVal.count = results.length;
return retVal;
}).then(showPopup);
function showPopup(results) {
view.popup.content = results.content;
view.popup.title = "All Soil Data: (" + results.count + " results)";
view.popup.open({location: event.mapPoint});
dom.byId("viewDiv").style.cursor = "auto";
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
