Is there a way to capture when the latestObservation graphic is updated by the TemporalRenderer? Using the TemporalRenderer with a FeatureLayer populated by a featureCollectionObject, can I capture the event when the latest graphic is updated on the map? I would like to update a table with that graphic's latest attributes. I can use the "graphic-draw" event, yet this only occurs if that graphic is visible in the current map extent and not all graphics that are being updated at that given time. Plus, the "graphic-draw" event captures my historic graphics as well as the latest graphic. The feature layer's "update-end" fires for each graphic also, yet how do you know which graphic was updated in that event? The "graphic-add" does not help either, since all my graphics are loaded to the map at one time and then displayed via the TemporalRenderer. Any ideas? Thanks!
