Is there something similar to the District Lookup Widget for JavaScript Maps SDK?
345
10-19-2023 07:21 AM
JaredPilbeam2
MVP Regular Contributor
Is there something similar to the District Lookup Widget you can use with the JavaScript SDK?
I'd like to search an address and display the features of a hosted feature layer.  Using the Search widget with multiple sources example , it allows me to search by features of a feature layer, however this requires the user to know what to look for. I'm looking enter an address to get the feature and its attributes--something similar to the District Lookup Widget.
This is what I currently have using the search widget.
<html lang="en">
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Access Will County</title>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.27/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.27/"></script>
    <script>
        require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/widgets/Search"], (
            Map,
            MapView,
            FeatureLayer,
            Search
            const map = new Map({
                basemap: "dark-gray-vector"
            const view = new MapView({
                container: "viewDiv",
                map: map,
                center: [-88, 41.5], // lon, lat
                scale: 1000000
            const featureLayerService = new FeatureLayer({
                url:
                    "https://services.arcgis.com/fGsbyIOAuxHnF97m/arcgis/rest/services/DialARide_Service_Areas/FeatureServer",
                popupTemplate: {
                    // autocasts as new PopupTemplate()
                    title: "Service Area: {Service}",
                    overwriteActions: true
            const searchWidget = new Search({
                view: view,
                //   allPlaceholder: "Search",
                searchAllEnabled: false,
                includeDefaultSources: false,
                sources: [
                        name: "Search by address",
                        placeholder: "search by address",
                        apiKey: "Your API Key Here",
                        singleLineFieldName: "SingleLine",
                        url: "https://geocode-api.arcgis.com/arcgis/rest/services/World/GeocodeServer"
                        layer: featureLayerService,
                        searchFields: ["Service"],
                        displayField: "Service",
                        exactMatch: false,
                        outFields: ["Service"],
                        name: "Search by Service Area",
                        placeholder: "example: Will Ride"
            // Add the search widget to the top left corner of the view
            view.ui.add(searchWidget, {
                position: "top-right"
    </script>
</head>
<body>
    <div id="viewDiv"></div>
</body>
</html>
vmvargas
New Contributor II
Try this one code
view: view,
sources: [{
url: "https://__________/arcgis/rest/services/GeocodeServer",
singleLineFieldName: "street",
autoComplete: true,
zoomScale: 2000,
placeholder: "***************",
locationEnabled: false,
exactMatch: false,
maxResults: 3,
maxSuggestions: 10,
suggestionsEnabled: true,
minSuggestCharacters: 0,
displayField: "Street",
outFields: ["Street", "Score"],
//prefix: '%',
//suffix: '',
resultSymbol: {
type: "picture-marker",
url: "https:/PIN.png",
height: 20
