Issues with creating a definitionExpression ArcGIS API for Javascript
1035
7
05-22-2017 02:39 PM
JacobTodd2
New Contributor III
I am having issues setting a definitionExpression based on OnDemandGrid row selection with ArcGIS API for Javascript. I keep getting an error stating that definitionExpression is not a function and I don't understand why. Below is my code:
var selectedRows = [];
          grid.on('dgrid-select', function (event) {
              var stateName = event.rows[0].data.stateName;
              var rows = event.rows;
              for (i = 0; i < rows.length; i++) {
                  selectedRows.push(stateName);
              for (i = 0; i < selectedRows.length; i++) {
                  stateLayer.definitionExpression('STATE_NAME = "' + i + '"');
              console.log(selectedRows);
RobertScheitlin__GISP
Jacob,
   It look like your code should be:
stateLayer.definitionExpression("STATE_NAME = '" + selectedRows[i] + "'");
Assuming the state name field is looking for a string and not an integer like you currently have it. I also swapped your single and double quotes around.
JacobTodd2
New Contributor III
Hi Robert,
Thanks for looking at this. I think you are right about making sure I am calling a string, but unfortunately that change didn't fix the definition expression error.
Jacob,
   I am kind of confused by you code on closer examination. Why are you looping twice?
//Why not
              stateLayer.definitionExpression("STATE_NAME = '" + stateName  + "'");
JacobTodd2
New Contributor III
Hi Robert,
The reason I was looping twice was to create a list of the selected rows in my grid. My end goal with this is to dynamically create a definition expression out of the selected rows. As rows are selected and the definition expression is created, I would like my map to zoom and center on envelope (extent) of my selections. I know that this is a lot to do at once, but any suggestions would be great. By the way I am using 4.3.
Jacob
Jacob,
   Then it would be something more like this:
              var stateName; = event.rows[0].data.stateName;
                  stateName = rows[i].data.stateName;
                  selectedRows.push("'" + stateName + "'");
              stateLayer.definitionExpression("STATE_NAME IN(" + selectedRows.join(',') + ")");
JacobTodd2
New Contributor III
Robert,
That worked great. What do you suggest out zooming to the extent of the selection?
Jacob,
   Query the layer for extent using the SQL statement previously.
https://developers.arcgis.com/javascript/latest/api-reference/esri-tasks-QueryTask.html#executeForEx...
