javascript API 4.6 - Error not throwing up in mapView promise callback
738
01-26-2018 06:04 AM
MaximeDemers
I notice that error that are thrown in the mapView constructor callback are not displayed in the browser console.
For instance:
var view = new MapView({
    "container": "viewDiv",
    "map": map,
    "zoom": 7
}).when(function(view) {
    throw new Error("This error is not displayed in the browser console");
    alert("This alert is not executed");
}, function(error) {
    console.error(error);
This is really difficult to know where the code is breaking. Is there a solution for this?
YannCabon
This is a normal behavior. Here is an snippet using JS Promise that reproduce the same behavior:
Promise.resolve().then(
    throw new Error("throwing in the then() callback")
  (error) => {
    console.error("not catching the error", error);
.catch(error => {
  console.error("catching the error", error);
You will see that the error callback won't react to what's happening in the success callback.
As a good practice, I never use the error callback, only chain with .catch
.catch(error => {
Your code snippet would look like:
        "map": map,
        "zoom": 7
      view.when(function(view) {
        throw new Error("This error is displayed in the browser console");
      .catch(function(error) {
Also, make sure to first assign view to the MapView instance.
// DON'T
var view = new MapView().when(); // view is a promise
// DO
var view = new MapView();  // view is a MapView
var promise = view.when();
YannCabon
  (error) => {
.catch(error => {
.catch(error => {
        "map": map,
        "zoom": 7
// DON'T
// DO
MaximeDemers
Ok thank you! I was confuse because the documentation shows example using the .when() errorCallback instead of the normal promise.catch function. When the .when() errorCallback would be called then?
