Javascript error: function not defined????
62258
12
08-26-2013 08:24 AM
by Anonymous User
Not applicable
however it IS defined....here:
require(["dojo/dom",
        "dojo/_base/array",
        "dojo/_base/Color",
        "dojo/parser",
function(dom, array, Color, parser, Map, esriLang, Graphic, FeatureLayer, InfoTemplate, GraphicsLayer, SimpleRenderer, Point, FeatureSet,
             ClosestFacilityTask, ClosestFacilityParameters, SimpleMarkerSymbol, SimpleLineSymbol){
      var map, incidentsGraphicsLayer, routeGraphicLayer, closestFacilityTask, params, facilitiesFeatureLayer, handler;
    function myFunction() {
      alert("Do Something");
<body class="claro">
<div> <button onClick="myFunction()">Pick Point</button></div>
</body>
</html>
by Anonymous User
Not applicable
Try this:
Add value as property:
[HTML]<input id="toolBuffer" data-dojo-type="dijit/form/Button" data-dojo-props="iconClass:'findNear', showLabel: false, value: 'buff'"></button>[/HTML]
Use .get('value') to get the value:
dom.byId('toolBuffer').get('value');
Throws this error:
Uncaught TypeError: Object #<HTMLSpanElement> has no method 'get'
BenFousek
Occasional Contributor III
Sorry...use dijit.byId because it's a widget.
dijit.byId('toolBuffer').get('value');
by Anonymous User
Not applicable
That was it....
Thanks!
rGibson
