Ok, I think I solved both problems.
For watchUtils:
import * as watchUtils from '@arcgis/core/core/watchUtils.js';
For button the best solution is (this example put as icon the esri-icon-collection):
var element = document.createElement('div');
element.className = "esri-icon-collection esri-widget--button esri-widget esri-interactive";
element.addEventListener('click', function(evt){
console.log("clicked");
view.ui.add(element, "top-right");
If you are using ionic, you can put a ionic icon removing 'esri-icon-collection ' and adding a innerHTML, like;
element.className = "esri-widget--button esri-widget esri-interactive";
element.innerHTML = '<ion-icon name="expand"></ion-icon>'
