David,
Here is a sample app that uses the where clause in a LabelClass (and it works just fine):
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title></title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; text-align: center; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#map{ margin: 0; padding: 0; }
#feedback {
background: #fff;
color: #444;
font-family: arial;
left: 30px;
margin: 5px;
padding: 10px;
position: absolute;
top: 30px;
width: 300px;
z-index: 40;
#note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; }
#loading { visibility: hidden; }
#legendDiv { padding: 10px 0 0 0; }
</style>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
// one global for persistent app variables
var app = {};
require([
"esri/map",
"esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
"esri/request", "esri/config",
"esri/tasks/ClassBreaksDefinition", "esri/tasks/AlgorithmicColorRamp",
"esri/tasks/GenerateRendererParameters", "esri/tasks/GenerateRendererTask",
"esri/layers/LayerDrawingOptions", "esri/layers/LabelClass","esri/symbols/TextSymbol",
"esri/symbols/SimpleFillSymbol", "esri/dijit/Legend",
"dojo/parser", "dojo/_base/array", "esri/Color", "dojo/dom-style",
"dojo/json", "dojo/dom",
"dojo/data/ItemFileReadStore",
"dijit/registry",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/FilteringSelect",
"dojo/domReady!"
], function(
Map,
ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
esriRequest, esriConfig,
ClassBreaksDefinition, AlgorithmicColorRamp,
GenerateRendererParameters, GenerateRendererTask,
LayerDrawingOptions,LabelClass,TextSymbol,
SimpleFillSymbol, Legend,
parser, arrayUtils, Color, domStyle,
JSON, dom,
ItemFileReadStore,
registry
parser.parse();
app.dataUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2";
app.defaultFrom = "#ffffcc";
app.defaultTo = "#006837";
app.map = new Map("map", {
center: [-86.708254, 33.053200],
zoom: 8,
slider: false
var basemap = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer");
app.map.addLayer(basemap);
var ref = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer");
//app.map.addLayer(ref);
// add US Counties as a dynamic map service layer
urlDyn = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
usaLayer = new ArcGISDynamicMapServiceLayer(urlDyn, {
opacity: 0.7,
visible: false
usaLayer.setVisibleLayers([2]);
app.map.addLayer(usaLayer);
// get field info
var countyFields = esriRequest({
url: app.dataUrl,
content: {
f: "json"
callbackParamName: "callback"
countyFields.then(function(resp) {
var fieldNames, fieldStore;
fieldNames = { identifier: "value", label: "name", items: [] };
arrayUtils.forEach(resp.fields.slice(6, 16), function(f) { // add some field names to the FS
fieldNames.items.push({ "name": f.name, "value": f.name });
fieldStore = new ItemFileReadStore({ data: fieldNames });
registry.byId("fieldNames").set("store", fieldStore);
registry.byId("fieldNames").set("value", "POP2007"); // set a value
}, function(err) {
console.log("failed to get field names: ", err);
// hide the loading icon when the counties layer finishes updating
usaLayer.on("update-end", function() {
domStyle.set("loading", "visibility", "hidden");
// update renderer when field name changes
registry.byId("fieldNames").on("change", getData);
registry.byId("fieldNames").set("value", "POP_2007"); // triggers getData()
function getData() {
// dynamic layer stuff
var optionsArray = [];
var drawingOptions = new LayerDrawingOptions();
var labelClass = new LabelClass({
labelExpression: '[' + (registry.byId("fieldNames").get("value") || "POP2000") +']',
labelPlacement: 'esriServerPolygonPlacementAlwaysHorizontal',
symbol: new TextSymbol(),
where: "STATE_NAME = 'Alabama'"
drawingOptions.labelingInfo = [labelClass];
drawingOptions.showLabels = true;
// set the drawing options for the relevant layer
// optionsArray index corresponds to layer index in the map service
optionsArray[2] = drawingOptions;
app.map.getLayer("us_counties").setLayerDrawingOptions(optionsArray);
app.map.getLayer("us_counties").show();
function errorHandler(err) {
console.log("error: ", JSON.stringify(err));
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'">
<div id="feedback" class="shadow">
<h3>Change the Attribute Field Used to Render Data</h3>
<div id="info">
<div id="note">
Note: This sample requires an ArcGIS Server version 10.1 map service to generate a renderer.
</div>
<!-- filtering select -->
<label for="fieldNames">Render based on: </label>
<select id="fieldNames" name="baseSym"
data-dojo-type="dijit/form/FilteringSelect"
data-dojo-props="style:'width:200px;'">
</select>
<img id="loading" src="http://dl.dropbox.com/u/2654618/loading_black.gif" />
<div id="legendDiv"></div>
</div>
</div>
</div>
</div>
</body>
</html>
