<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>LayerList widget - 4.3</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.3/"></script>
<script>
require([
"esri/views/SceneView", "esri/layers/GraphicsLayer",
"esri/widgets/LayerList",
"esri/WebScene",
"dojo/domReady!"
], function(
SceneView, GraphicsLayer, LayerList, WebScene
var scene = new WebScene({
portalItem: { // autocasts as new PortalItem()
var view = new SceneView({
container: "viewDiv",
map: scene
var parcelGL;
parcelGL = new GraphicsLayer();
scene.add(parcelGL);
view.then(function() {
var layerList = new LayerList({
view: view
// Add widget to the top right corner of the view
view.ui.add(layerList, "top-right");
</script>
</head>
Thank you.
