LayerSwipe destroy
1476
17
10-13-2013 10:16 PM
OrenGal
New Contributor III
I have a toggle button for enabling and disabling the LayerSwipe.
After destroy(), one of the layers in the swipe is cropped.
application: http://gisn.tel-aviv.gov.il/iview2js/index.aspx
Tried in addition to add these lines to the destroy function:
LayerSwipe.disable();
LayerSwipe.destroy();
LayerSwipe=null;
CroppedTiledLayer.hide();
CroppedTiledLayer.show();
CroppedTiledLayer.refresh();
CroppedTiledLayer.resume();
But still layer is cropped (only sometimes, mostly IE10, can't understand it).
Oren.
MattDriscoll
Try this file. I think you just need to remove the 'zesri'. That's just there so that it's loaded as a custom module. This file should work though.
MattDriscoll
Hi Oren,
It sounds like the CSS clip isn't being removed in some IE. I'll dig deeper to see if I can find a solution. Since you already called .disable() that "should" have cleared it up but apparently it isn't working. I will check in an update on github and let you know when there's a fix. there might be a easy solution as well.
I just need to figure out the correct way to clear the CSS clip on the layer's node for the IE that is failing.
Thanks
MattDriscoll
The IE issue should be fixed for next version.
You can grab the latest code here if you need it now: https://github.com/driskull/arcgis-dijit-layer-swipe-js
Let me know if you still see the issue here:
http://driskull.github.io/arcgis-dijit-layer-swipe-js/
OrenGal
New Contributor III
Hi Matt,
Thanks for the fast fix! How do I merge the LayerSwipe.js from GitHub to my project?
Tried to put the file here  ..\wwwroot\arcgis_js_api\library\3.7\3.7\js\esri\dijit
but then the app didn't start. What am I missing?
Oren
MattDriscoll
OrenGal
New Contributor III
Didn't remove a thing. just copied it. Works like a charm.
Thanks again Matt!
http://gisn.tel-aviv.gov.il/iview2js/index.aspx  (with fix)
MattDriscoll
Cool. this will be in 3.8.
OrenGal
New Contributor III
Hi Matt,
I have another minor minor issue: when I press the first time the toggle button,
the splitter appears but the background is not changed.
Only when I start to move the splitter right or left, only then the background changes.
Can you please check it?
Oren
MattDriscoll
Hi Oren,
It's kind of hard to test since the services are so slow viewing from here. Is it just the first time that's a problem?
Can you try the attached?
I also see an error with a layer.
OrenGal
New Contributor III
Thanks Matt, but the result remains.
I will make a small project and send you with Esri services.
Oren
