<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Map with legend</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
<link rel="stylesheet" type="text/css" href="http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs/css/agsjs.css" />
<style>
html, body {
height: 97%;
width: 98%;
margin: 1%;
#rightPane {
width: 20%;
#legendPane {
border: solid #97DCF2 1px;
</style>
<script>
var dojoConfig = {
//parseOnLoad: true,
packages: [
//location: location.pathname.replace(/\/[^/]+$/, "") + '../../agsjs'
"location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs' // for xdomain load
</script>
<script src="http://js.arcgis.com/3.9/"></script>
<script>
var map, layerDynamic, toc, layerInfo;
require([
"esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/_base/array", "dojo/parser", "agsjs/dijit/TOC",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dijit/layout/AccordionContainer", "dojo/domReady!"
], function (
Map, ArcGISDynamicMapServiceLayer,
arrayUtils, parser, TOC
parser.parse();
map = new Map("map", {
basemap: "oceans",
center: [-86, 30],
zoom: 6
layerDynamic = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer", {
map.on("layers-add-result", function (evt) {
toc = new TOC({
map: map,
layerInfos: [{
layer: layerDynamic,
title: "Legend",
collapsed: true
//layerList: layerInfo
}, 'legendDiv');
toc.startup();
map.addLayers([layerDynamic]);
</script>
</head>
<body class="claro">
<div id="content"
data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline', gutters:true"
style="width: 100%; height: 100%; margin: 0;">
<div id="rightPane"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'right'">
<div data-dojo-type="dijit/layout/AccordionContainer">
<div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
data-dojo-props="title:'Legend', selected:true">
<div id="legendDiv"></div>
</div>
data-dojo-props="title:'Pane 2'">
</div>
</div>
</div>
<div id="map"
data-dojo-props="region:'center'"
style="overflow: hidden;">
</div>
</div>
</body>
</html>
