Legend from JSON Object
1970
05-10-2012 05:40 AM
demdeberanz
New Contributor II
Hi everybody,
Is it possible to create a legend of a specific layer belonging to a dynamic map service layer using the json object returned from the web map service's rest interface?
(accessible from .../<map service name>/MapServer/legend ....)
Thank you very much.
ShreyasVakil
Occasional Contributor II
demdeberanz
New Contributor II
See if this helps!
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm#jsapi/legend.htm
Hi Svakil,
   thank you for your reply. I've already checked out that example but I couldn't get anything useful. Because what I need is to draw a legend only for certain layer accessible from the DynamicMapServiceLayer I'm using. What I'm able to do is to draw all the legends from all the layers of the DynamicMapServiceLayer or I manage to draw the legend of a single FeatureLayer but I can not draw selectively the legend of the layers accessible from the DynamicMapServiceLayer.
Any ideas???
Many thanks.
ShreyasVakil
Can you post some code?
demdeberanz
New Contributor II
I haven't got any code 🙂 the only code I used is the one of the link you have given.
demdeberanz
New Contributor II
Hi guys,
   I succeeded in creating legend for single specific layers with the template picker. But now I not able to show it. Better, I can show one legend in one div but if create as many divs as I need no one legend is displayed (firebug display in gray the html code of the legend div ). Why?
layers2.push(new esri.layers.FeatureLayer(****************));
              dojo.connect(layers2[0], "onLoad", function (lay) {
                  var symbols2 = dojo.map(lay.renderer.infos, function (info) {
                      return { label: info.label,
                          symbol: info.symbol
                  var wdg3= new esri.dijit.editing.TemplatePicker({
                      //featureLayers: lay,
                      items: symbols2,
                      rows: 2,
                      columns: 2,
                      showTooltip: true,
                      style: "height: 100px !important; width: 300px !important;"
                  }, "testLegend2");
                  wdg3.startup();
Thank you all very much
