Map with a single feature layer won't display a legend
5607
9
07-25-2014 07:45 AM
DonaldLund
New Contributor II
I have a map with a single feature layer, layered over a base map, and I can't get the javascript API to display a legend for it. If I throw in another layer, the legend displays. I'm following code example here: Legend | ArcGIS API for JavaScript. Why won't the legend display when only a single feature layer is defined? Do I have to define a dummy feature layer in order to display a legend? Is the legend widget using some kind of an array or something that requires more than one layer to be defined in order for it to work properly or display anything at all?
Any help or insights would be appreciated.
TimWitt2
Donald,
After line 59 add:
if (layerInfo.length > 0) {
After line 64 add:
and replace 66 with:
map.addLayers([rivers]);
Whatever you have as your rivers layer will show up in your Legend.
Hope this answers your question.
Tim
TimWitt2
Donald,
you need to make sure that the featurelayer is actually visible on the map or it wont show in your legend. Some layers are configured to not show on a certain scale and once you zoom in/ out they start to show. Are you able to post a link to the layer that won't show?
Tim
DonaldLund
New Contributor II
Tim,
Thanks for the quick response.
The layer polygons are actually visible on the map, but the legend is blank. The feature layer is actually based on a county shapefile for the state of Michigan.
I am not able to share a link because of the strategic nature of the data. If I don't make any progress, perhaps I can make a layer with bogus data that I can share.
Either way, I'll be back.
Thanks again.
TimWitt2
Are you able to post your code, just remove the sensitive information?
DonaldLund
New Contributor II
Sure. Here you go. And thanks.
FYI, the layer named 'waterbodies' is the one I'm using as a dummy layer that I toggle on and off. When it's on, the legend appears. When it's off the legendDiv content pane appears empty.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Map with legend</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
      border: solid #97DCF2 1px;
  </style>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var ccdURL="http://services2.arcgis.com/and the rest of the URL/FeatureServer/0";
    var token="?token=token string goes here";
    ccdURL=ccdURL+token;
    var map;
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/layout/AccordionContainer", "dojo/domReady!"
    ], function(
      Map, FeatureLayer, Legend,
      arrayUtils, parser
      parser.parse();
      map = new Map("map", {
        basemap:"topo",
        center: [-85.7, 44.1],
        zoom: 7
      var rivers = new FeatureLayer(ccdURL, {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields:["*"]
// this is a dummy layer I threw in just to make the legend work. If this is
// commented out, the legend will appear blank
      var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/0", {
        outFields:["*"]
      //add the legend
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        var legendDijit = new Legend({
          map: map,
          layerInfos: layerInfo
        }, "legendDiv");
        legendDijit.startup();
      map.addLayers([rivers, waterbodies]);
//      map.addLayer(rivers);
// I comment the frist line and use the second when I toggle off the dummy layer
  </script>
</head>
<body class="claro">
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Pane 2'">
        This pane could contain tools or additional content
      </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
</div>
</body>
</html>
TimWitt2
Donald,
After line 59 add:
After line 64 add:
Tim
DonaldLund
New Contributor II
Tim, you're a genius.
It turns out I had the layerInfo.length check on in earlier versions, and may have accidentally stripped it out when posting the example code.
The real key to making this work was changing map.addLayer(rivers) to map.addLayers([rivers]). Any idea why the former won't display a legend. Seems like it's some sort of an array thing.
TimWitt2
You are right it has to do with an array. It trys to cycle through your add.Layers array, but when you don't use [], there is no array.
DonaldLund
New Contributor II
Thanks Tim.
Regards,
Don
SatyanarayanaNarmala
New Contributor III
Hi TIM,
Here is my code, where legend does not show anything
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title> </title>
          <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
    <style type="text/css">body,html,#main{margin:0;padding:0;height:100%;width:100%;}</style>
      <script src="http://js.arcgis.com/3.13/"></script>
    <script>dojoConfig = { parseOnLoad: true };</script>
    <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 90%;
    #legendPane {
  </style>
    <style>
      html, body, #map {
        padding: 0;
        margin: 0;
        height: 100%;
      /* Change color of icons to match bar chart and selection symbol */
       .esriPopup.dark div.titleButton,
      .esriPopup.dark div.titlePane .title,
      .esriPopup.dark div.actionsPane .action {
        color: #000000;
        font-weight: bold;
      /* Additional customizations */
      .esriPopup.dark .esriPopupWrapper {
        border: none;
      .esriPopup .contentPane {
        text-align: left;
      .esriViewPopup .gallery {
        margin: 0 auto;
      .title {
          padding:10px;
          background:#fafafa;
      .title .logo img {
          float:left;
          margin-right:10px;
      .title .logo h1{
        color: #C9584F;
        padding: 0px;
        font-size: 30px;
        font-weight: bold;
        float:left;
        font-family:Arial, Helvetica, sans-serif;
        margin:0px;
               .title .logo h1>span{
        color: #111;
        padding: 0px;
        font-size: 20px;
        font-weight: bold;
      .title .cm {
          float:right;
          text-align:center;
          color: #C9584F;
  1.           font-size:15px;
        .title .cm h2{
          color: #C9584F;
          font-size:15px;
    </style>
    <script>
    var map;
    var veTileLayer;
     var findTask, findParams;
     var center, zoom;
     var grid, store, store3;
    var county;
    var resizeTimer;
      require([
      "esri/map", "esri/tasks/query", "dojo/parser",  "esri/dijit/Legend", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
          "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "dojo/_base/array","dojo/DeferredList",
      "dijit/form/ComboBox", "dojo/data/ItemFileReadStore","dojo/store/Memory",
      "esri/virtualearth/VETiledLayer", "dijit/form/Button",
      "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "dijit/registry",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
      "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar",
       "dojo/on", "dijit/layout/AccordionContainer", "dojo/domReady!"],
      function(Map, query, parser, BorderContainer, ContentPane, Legend,
                IdentifyTask, IdentifyParameters,arrayUtils,DeferredList,
                ComboBox, ItemFileReadStore, Memory,
             VETiledLayer, Button,
             FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, registry, connect, DataGrid,
                Popup, PopupTemplate,
                FeatureLayer,
                SimpleFillSymbol, Color,
                domClass, domConstruct,
                Chart, theme,
                on, Scalebar) {
        parser.parse();
         registry.byId("mySelect1").on("change", doFind);
   /* map = new Map("map");
    function init() {
        //Creates the Virtual Earth layer to add to the map
        //Example for adding a Bing Maps key
        // bingMapsKey:  "1B2C3OlkbxWHYa1b2c3qkPrO_Ou3nRrGtSa_5Op-xvPNya1b2c3",
        veTileLayer = new esri.virtualearth.VETiledLayer({
          bingMapsKey:'Ame5R45lEOTdPXxlhxuAXN2sDT8vyEJcgXGeZpPOPHBLbg2XqkPMaL5OJHp0OlV0',
          mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
        map.addLayer(veTileLayer);
        infoWindow: popup
      dojo.ready(init);*/
        var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
        var popup = new Popup({
            fillSymbol: fill,
            titleInBody: false
        }, domConstruct.create("div"));
        //Add the dark theme which is customized further in the <style> tag at the top of this page
        domClass.add(popup.domNode, "dark");
        findTask = new FindTask("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/");
           basemap: "satellite",
           /*center: [-122.45, 37.75], // longitude, latitude */
           center : [79.2, 18.10],
           zoom: 6,
           infoWindow: popup
        var template = new PopupTemplate({
          title: "SWACHH TELANGANA APPLICANTS    <BR>",
          description: "<BR>BENEFICIARY ID: {beneficiary_id} <br> <br>BENEFICIARY NAME: {applicant_name} <br><br>FATHERS NAME: {fathername}<br><br> ADDRESS: {address} <br><br> CASTE: {caste} <br> <br> MOBILE: {mobile} <br><br> AADHAR NO:: {aadhar_number}<br><br> COMMUNICATION STATUS: {comm_status} <br><br>  PHOTO: <a href=http://swachhts.cgg.gov.in/photos_uploaded/{applicant_photo} > <img src={applicant_photo} WIDTH=200 HEIGHT=200></a> <br><br> SITE PHOTO : <a href=http://swachhts.cgg.gov.in/photos_uploaded/{applicant_site_photo} > <img src={applicant_site_photo} WIDTH=200 HEIGHT=200></a> <br><br> STAGE : {stage}<br>",
        var featureLayer = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/0",{
          outFields: ["*"],
          infoTemplate: template
         var rivers = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/0", {
        outFields:["*"]
      var waterbodies = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/2", {
        outFields:["*"]
     veTileLayer = new VETiledLayer({
        //map.addLayer(featureLayer);
                var polygonQuery = null;
                var polygonQueryTask = null;
        var polygonQuery1 = null;
                var polygonQueryTask1 = null;
                // RIYAS: Wait till map is loaded before firing query, needed for getting map spatial reference
        map.on("load", function () {
                        var queryTask = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/2");
                        highlightSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255,0,0]));
            symbol321 = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 0.1, null, new Color([255, 255, 0, 0.5]));
           // var queryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/sample/pattasample/MapServer/2");
                        //Define query parameters
                        var query = new esri.tasks.Query();
                        query.outFields = ["dname"];
                        query.returnGeometry = true;
                        query.outSpatialReference = map.spatialReference;                // RIYAS: Set query to return shape in map's spatial reference
                        query.where  = "dname <> ''"
                        queryTask.execute(query,populateList);
                        /*var query1 = new esri.tasks.Query();
                        query1.outFields = ["dname", "mname"];
                        query1.returnGeometry = true;
                        query1.outSpatialReference = map.spatialReference;                // RIYAS: Set query to return shape in map's spatial reference
                        query1.where  = "mname<> ''"
                        queryTask1.execute(query1,populateList1);*/
                        // RIYAS: Setup query to behave as identify
                        polygonQueryTask = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/2");
                        polygonQuery = new esri.tasks.Query();
                        polygonQuery.returnGeometry = true;
                        polygonQuery.outFields = ["dname"];
                        polygonQuery.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
                        polygonQuery.outSpatialReference = map.spatialReference;
                        polygonQueryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/1");
                        polygonQuery1 = new esri.tasks.Query();
                        polygonQuery1.returnGeometry = true;
                        polygonQuery1.outFields = ["place", "name"];
                        polygonQuery1.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
                        polygonQuery1.outSpatialReference = map.spatialReference;
                        findParams = new FindParameters();
                        findParams.returnGeometry = true;
                        findParams.layerIds = [0];
                        findParams.searchFields = ["town_city"];
                        findParams.outSpatialReference = map.spatialReference;
                        console.log("find sr: ", findParams.outSpatialReference);
                var infoTemplate = new esri.InfoTemplate("District: ${dname}", "District : ${dname}<br/>");
                var infoTemplate1 = new esri.InfoTemplate("DISTRICT: ${place}", "District : ${place}<br/> Mandal : ${name}<br/> ");
                var infoTemplates = [infoTemplate, infoTemplate1];
                //map.on("click", executeIdentifyTask);
                // RIYAS: Execute query to behave as identify
                function executeIdentifyTask (where, pnt) {
          //polygonQuery.where = event.mapPoint;
          //polygonQuery1.where = event.mapPoint;
          polygonQuery.where = where;
          polygonQuery1.where = where;
          var deferred = polygonQueryTask
            .execute(polygonQuery);
          var deferred1 = polygonQueryTask1
            .execute(polygonQuery1);
          // InfoWindow expects an array of features from each deferred
          // object that you pass. If the response from the task execution
          // above is not an array of features, then you need to add a callback
          // like the one above to post-process the response and return an
          // array of features.
          var defList = new DeferredList([deferred, deferred1]).then(function (results){
            var features = [];
            arrayUtils.forEach(results,function(result, idx){
                if (result[0] === true){
                    features = features.concat(arrayUtils.map(result[1].features, function (feature) {
                                feature.setInfoTemplate(infoTemplates[idx]);
                        return feature;
            map.infoWindow.setFeatures(features);
            map.infoWindow.show(pnt);
        //var initialExtent = new esri.geometry.Extent(-85.915,38.105,-85.52,38.33,
        //      new esri.SpatialReference({wkid:4326}) );
        // map = new esri.Map("map", {extent:initialExtent});
        //Create tiled and dynamic map services and add to the map - for the dynamic service set the transparency
        //and provide an id so we can access it later
       // map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer"));
        map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer",
                {"opacity":1,"id":"dynamic"}));
      function populateList(results) {
        //initialize InfoTemplate
        //create symbol for selected features
            symbol = new esri.symbol.SimpleMarkerSymbol();
            symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
            symbol.setSize(0.1);
            symbol.setColor(new dojo.Color([255, 255, 0, 0.5]));
        //Populate the dropdown list box with unique values
       // var county;
        var values = [];
        var testVals={};
        //Add option to display all zoning types to the dropdown list
        values.push({name:""})
        var features = results.features;
        dojo.forEach (features, function(feature) {
          county = feature.attributes.dname;
          if (!testVals[county]) {
            testVals[county] = true;
            values.push({name:county,shape:feature.geometry,centroid: feature.geometry.type === "point" ? feature.geometry : feature.geometry.getCentroid() }); // RIYAS: set shape to list store
        var dataItems = {
               identifier: 'name',
               label: 'name',
               items: values
        var store = new dojo.store.Memory({data:dataItems});
        dijit.byId("mySelect").store = store;
        //remove all graphics on the maps graphics layer
        map.graphics.clear();
        //Performance enhancer - assign featureSet array to a single variable.
        var resultFeatures = results.features;
        //Loop through each feature returned
        for (var i = 0, il = resultFeatures.length; i < il; i++) {
                //Get the current feature from the featureSet.
                //Feature is a graphic
                var graphic = resultFeatures;
                graphic.setSymbol(symbol);
                //Set the infoTemplate.
                graphic.setInfoTemplate(infoTemplate);
                //Add graphic to the map graphics layer.
                map.graphics.add(graphic);
                // This takes the graphics array you get back from your query and
                // gets the overall extent for them. Make sure return geometry is set to
                // true in your query.
                var extent = esri.graphicsExtent(results.features);
                // Use that to set the extent, 1.5 is something I use in my app, but play with
                // it to find a setting you like, setting the second parameter to true will get you an extend
                // that is at the closest level of your cached service.
                map.setExtent(extent.expand(1.0), true);
      // this replaces your applyLayerDef() function
      dijit.byId("mySelect").on("change", function () {
        //Filter the layer to display only the selected zoning types
        var county = dijit.byId("mySelect").value;
        var centroid = dijit.byId("mySelect").item.centroid;
        if (county !== 'ALL') {
          var layerDefs = [];
          layerDefs[2] = "dname = " + "'" + county + "'";
          layerDefs.visibleLayers = [2];
                   map.setExtent(dijit.byId("mySelect").item.shape.getExtent(infoTemplate).expand(1.7));                // RIYAS: Get shape from list store and zoom to its extent
                  executeIdentifyTask("dname = '" + county + "'", centroid);
                  // RIYAS: cannot set layer defintion for dynamic map service.
          //map.getLayer("dynamic").setLayerDefinitions(layerDefs);
        else {
          //map.getLayer("dynamic").setDefaultLayerDefinitions();
            var queryTask1 = new esri.tasks.QueryTask("http://gisserver.cgg.gov.in/arcgis/rest/services/CDMA/swachhts/MapServer/1");
            query1.outFields = ["*"];
            query1.where  = "name <> '' and place ='"+dijit.byId("mySelect").value+"'"
       function populateList1(results1) {
/*        alert(dijit.byId("mySelect").value)
            symbol1 = new esri.symbol.SimpleMarkerSymbol();
            symbol1.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
            symbol1.setSize(0.1);
            symbol1.setColor(new dojo.Color([255, 255, 0, 0.5]));
        var city;
        var values1 = [];
        var testVals1={};
        values1.push({name:""})
        var features1 = results1.features;
        dojo.forEach (features1, function(feature1) {
          city = feature1.attributes.name;
          if (!testVals1[city]) {
            testVals1[city] = true;
            values1.push({name:city,shape:feature1.geometry,centroid: feature1.geometry.type === "point" ? feature1.geometry : feature1.geometry.getCentroid()}); // RIYAS: set shape to list store
        var dataItems1 = {
               identifier: 'name',
               label: 'name',
               items: values1
        var store1 = new dojo.store.Memory({data:dataItems1});
        dijit.byId("mySelect1").store = store1;
        var resultFeatures1 = results1.features;
        for (var i = 0, il = resultFeatures1.length; i < il; i++) {
                var graphic1 = resultFeatures1;
                graphic1.setSymbol(symbol1);
                graphic1.setInfoTemplate(infoTemplate1);
                map.graphics.add(graphic1);
                var extent1 = esri.graphicsExtent(results1.features);
                map.setExtent(extent1.expand(1.0), true);
      dijit.byId("mySelect1").on("change", function () {
        var city = dijit.byId("mySelect1").value;
        var centroid = dijit.byId("mySelect1").item.centroid;
        if (city !== 'ALL') {
          var layerDefs1 = [];
          layerDefs1[2] = "name = " + "'" + city + "'";
          layerDefs1.visibleLayers = [2];
        //alert(dijit.byId("mySelect1").value)
                   map.setExtent(dijit.byId("mySelect1").item.shape.getExtent(infoTemplate1).expand(1.7));                // RIYAS: Get shape from list store and zoom to its extent
                  executeIdentifyTask("name = '" + city + "'", centroid);
        else {
       function doFind() {
          //Set the search text to the value in the box
          var house = dijit.byId("mySelect1").value;
         //alert(house)
          findParams.searchText = house;
          findTask.execute(findParams, showResults);
      function showResults(results) {
          //This function works with an array of FindResult that the task returns
            symbol.setSize(1);
         // map.graphics.clear();
      //  var symbol = new SimpleFillSymbol(
          //  SimpleFillSymbol.STYLE_SOLID,
          //  new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
         //   new Color([98, 194, 204, 0.5])
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            return result.feature.attributes;
          //Create data object to be used in store
          var data = {
            identifier : "beneficiary_id", //This field needs to have unique values
            label : "beneficiary_id", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
          //Create data store and bind to grid.
          store = new ItemFileReadStore({
            data : data
          var grid = registry.byId("grid");
          grid.setStore(store);
          grid.on("rowclick", onRowClickHandler);
          //Zoom back to the initial map extent
          map.centerAndZoom(center, zoom);
        /* function onRowClickHandler(evt) {
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).benid;
          var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.benid === clickedTaxLotId[0]);
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
        function onRowClickHandler(evt){
            var FindDeceasedName = grid.getItem(evt.rowIndex).beneficiary_id;
            var SelectedFindDeceasedName;
            dojo.forEach(map.graphics.graphics,function(graphic){
                graphic.setSymbol(symbol321);
                if((graphic.attributes) && graphic.attributes.beneficiary_id === FindDeceasedName){
                    SelectedFindDeceasedName = graphic;
                    SelectedFindDeceasedName.setSymbol(highlightSymbol);
                    return;
        var FindDeceasedNameExtent = SelectedFindDeceasedName.geometry;
  var factor = -200;
  var extent;
        extent = new esri.geometry.Extent({ "xmin": FindDeceasedNameExtent.x - factor, "ymin": FindDeceasedNameExtent.y - factor, "xmax": FindDeceasedNameExtent.x + factor, "ymax": FindDeceasedNameExtent.y + factor, "spatialReference": { "wkid": 3857} });
  map.setExtent(extent);
      function resizeMap() {
        //Handle browser resize
        clearTimeout(resizeTimer);
        resizeTimer = setTimeout(function() {
          map.resize();
          map.reposition();
        }, 800);
            map: map,
          }, "legendDiv");
             map.addLayers([waterbodies, rivers]);
           // map.addLayer(featureLayer);
    </script>
  </head>
  <body class="claro"  oncontextmenu="return false">
  <div class="title">
                <div class="logo"> <a href="http://swachhts.cgg.gov.in/Login.do"><img src="http://elandts.cgg.gov.in:80/website/images/TSlogo.png" width="80" height="80" alt="logo"/>
                <h1> Swachh Bharat - Swachh Telangana <br><span>Commissioner & Director of Municipal Administration, Government of Telangana </span>                        </h1> </a>
                </div>
                <div class="logo"> <a href="http://swachhts.cgg.gov.in/Login.do"><img src="http://swachhts.cgg.gov.in:80/images/SBM-Logo.png" width="100" height="80" alt="logo"/>
                </a>
                </div>
                <div class="logo"> <a href="http://swachhts.cgg.gov.in/Login.do"><img src="http://swachhts.cgg.gov.in:80/images/swts_logo.png" width="100" height="80" alt="logo"/>
                </a>
                </div>
      <div class="cm">
      <div class="pull-right">
          <img src="http://elandts.cgg.gov.in:80/website/images/cm.png" style="" class="img-responsive" alt="cm" width="50"/> <br>
        <h2> Sri K.Chandrasekhar Rao <br>
                <span> Hon'ble Chief Minister of Telangana</span> </h2>
          </div>
      </div>
      <br clear="all">
      </div>
    <div id="main" style="width:2024px; height:800px; border:1px solid #000;"
            dojotype="dijit.layout.BorderContainer"
            design="headline"
            gutters="true">
      <div id="header"
             dojotype="dijit.layout.ContentPane"
             region="left"
             style="height:25px;">
        <select id="mySelect"
             dojotype="dijit.form.ComboBox"
             style="width:200px;font-size:18px;"
             autoComplete="true"
             forceValidOption="false"
             value="Select a District"></select> <BR> <BR>
        <select id="mySelect1"
             autoComplete="true"
             value="Select a Town"></select> <BR> <BR>
        <button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL);">Aerial</button>
        <button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL_WITH_LABELS)">Aerial with labels</button><BR> <BR>
        <!--<button data-dojo-type="dijit.form.Button" onClick="veTileLayer.setMapStyle(esri.virtualearth.VETiledLayer.MAP_STYLE_ROAD)">Roads</button>-->
  <div id="content"
     style="width: 100%; height: 50%; margin: 0;">
  <div id="rightPane"
                </div>
                </div>
            </div>
  </div>
  </div>
      </div>
      <div id="map"
             region="center"
             style="border:1px solid #000;margin:5px">
      </div>
    </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
      <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'6', rowSelector:'10px'">
        <thead>
          <tr>
            <th field="beneficiary_id" width="25%">BENEFICIARY ID</th>
            <th field="applicant_name" width="25%">APPLICANT NAME</th>
            <th field="fathername" width="25%">FATHERS NAME</th>
            <th field="aadhar_number" width="25%">AADHAR NO </th>
            <th field="stage" width="25%">STAGE</th>
            <th field="caste" width="25%">CASTE</th>
          </tr>
        </thead>
      </table>
    </div>
    </div>
        <div style="position:relative;">
    </div>
  </body>
</html>
