Measure Widget Issue - ArcGIS Javascript API 3.11
3313
11
10-07-2014 09:50 AM
by Anonymous User
Not applicable
I am having an issue with the Measure Widget in my application after updating to 3.11. The widget does not appear after the application loads. I have checked my code and do not see an issue, also when reverting back to 3.10 it works correctly.
Has anyone else had this issue after updating to 3.11?
measurement = new Measurement({
    map: map
}, dom.byId("measure_results"));
measurement.startup();
RobertScheitlin__GISP
Jeremy,
   Clear your browsers cache, restart your browser, Double check you require and function var sequence.
by Anonymous User
Not applicable
UPDATE
The widget is actually working, but the "esriMeasurementButtonPane" is not being parsed.  See screenshot below:
Jeremy,
   Using your browsers Developer tools, do you see any file in your network traffic that are not getting returned (i.e. 400 errors)?
by Anonymous User
Not applicable
No everything is returned fine.  In the other thread there was this post:
"I ran into some general css issues when moving up to 3.11 and they were all related to differences in the 'claro' theme in dojo 1.10.0"
Jeremy,
    It must be something in your apps css that you have modified that is preventing the proper css being applied to the esriMeasurementButtonPane. Can you try commenting out anything in your css that has to do with your host container that you have the measurement widget inside of?
by Anonymous User
Not applicable
I think I may have found the issue, I am getting the following error.
"Tried to register widget with id==dijit_layout_ContentPane_0 but that id is already registered"
This is widget ID of the Buttons for the Measure widget.  Any idea on how to fix this?
Jeremy,
by Anonymous User
Not applicable
I had parseOnLoad:true, which I changed to false.  I manually parsed my initial require which seems to have solved the issue.
JonathanUihlein
This is correct. When using templates or templated widgets, you will oftentimes need to call the parser manually.
JoshHevenor1
New Contributor III
My measure dijit was arguing with my SignIn window. If I built my measure dijit after signing was complete I was fine. That may just be a hacky workaround that did more or less what Jeremy did above.
