Measure Widget issue on IE 10
901
09-19-2014 03:56 AM
RyanSmith1
Hi all, I'm using the Measure tool on my web page, it works perfectly on firefox, chrome and IE 8 and 9 but on 10 it seems to be buggy. I'm using api version 3.4. I've been using the following example: http://help.arcgis.com/en/webapi/javascript/arcgis../samples/widget_measurement/
Ryan
KellyHutchins
Esri Frequent Contributor
Ryan,
We've done quite a bit of work on the measurement widget since version 3.4.  Do you experience issues in IE10 with the sample running on the current release (v 3.10) of the JSAPI?
Measurement | ArcGIS API for JavaScript
RyanSmith1
Hi Kelly, thanks for the response.
No issues on IE 10 with the current release(3.10). Another GeoNet user did stipulate that the (3.4) version was released before the first stable release of IE 10. So i guess i have to upgrade to (3.10). Please confirm
Ryan
KellyHutchins
Ryan,
Correct you will need to upgrade to take advantage of the fix. We released 3.11 Monday so you may just want to upgrade to that version.
