MGRS to lat long or UTM Conversion.
15576
16
10-05-2011 02:45 AM
RahulRahul
Can anyone please guide me on converting MGRS to lat/long or UTM.
Any help is greatly appreciated.
Rahul
PaulWalton1
No I just didn't know if you would still get the message from the old thread.
I noticed you supplied the code for the grid conversions to another user, I am currently doing a project and was hoping if you could supply it to me.
My email is paulboywal@gmail.com
It would be much appreciated.
JeffPace
the code is posted as a zip file in the 4th post of this thread
PaulWalton1
Jeff I have noticed a problem with your code. It doesn't give the correct lat and lon for southern hemisphere cases. I have managed to correct this by add an if statement in the UTMtoLL function. The if clause takes the UTMNorthing away from 10,000,000 and multiplies the Latitude by -1 if the UTM Letter is C-M.
AdamSmith2
Could you explain or show the code you used to fix the USNGtoLL function below the southern hemisphere?  I have a function that requires using this, and return NaN below the southern hemisphere when using this function.
TimWitt2
Adam,
maybe the code I used here can help.
It doesn't include utm though.
Location, Location, Location... - JSFiddle
Tim
AdamSmith2
So you use esri's geocoding service to convert to from USNG/MGRS to LL?
TimWitt2
Yes, I found out that's the easiest.
