I'm having a bit of an issue with multiple click events returning on a single mouse click and single click events returning after a pan or double click in Chrome and Firefox.I have a jsFiddle set up that shows this. I am logging the click events to the console so you will need to open developer tools to see the clicks. Here is the javascript I am using:var map; var clickCount = 0; require([ "esri/map", "dojo/domReady!"], function (Map) { map = new Map("divMap", { basemap: "topo", center: [-89.5, 40], zoom: 6 }); map.on("click", function(evt){ console.log("Clicked" + (++clickCount)); }); });
I'm using the 3.6 API.Any suggestions for a fix?Thanks,
