My Measurement Widget in ArcGIS Javascript API does not work
544
05-15-2023 02:07 AM
UsmanAziz
I tried to merge two of the ArcGis Javascript API widgets in sandbox and those are the basemap gallery and the measurement, however, the measurement widget does not work. The measurement widget does  not function in the sense that i am simply unable to measure on the map. Cannot select any points or I do not see any lines come up. What could the problem be and how do I go about fixing it?
<html lang="en">
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1, maximum-scale=1,user-scalable=no"
<title>
BasemapGallery widget | Sample | ArcGIS Maps SDK for JavaScript 4.26
</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.26/esri/themes/light/main.css"
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script src="https://js.arcgis.com/4.26/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/widgets/Expand",
"esri/widgets/BasemapGallery",
"esri/widgets/DistanceMeasurement2D",
"esri/widgets/AreaMeasurement2D"
], (Map, SceneView, Expand, BasemapGallery, DistanceMeasurement2D, AreaMeasurement2D) => {
const map = new Map({
basemap: "topo-vector"
const view = new SceneView({
container: "viewDiv",
map: map,
center: [-77.2627, 18.0927],
zoom: 10
const basemapGallery = new BasemapGallery({
view: view,
// Create an Expand instance and set the content
// property to the DOM node of the basemap gallery widget
// Use an Esri icon font to represent the content inside
// of the Expand widget
const bgExpand = new Expand({
view: view,
content: basemapGallery
// close the expand whenever a basemap is selected
basemapGallery.watch("activeBasemap", () => {
const mobileSize =
view.heightBreakpoint === "xsmall" ||
view.widthBreakpoint === "xsmall";
if (mobileSize) {
bgExpand.collapse();
// Add the expand instance to the ui
view.ui.add(bgExpand, "top-left");
// add the toolbar for the measurement widgets
view.ui.add("topbar", "top-right");
document
.getElementById("distanceButton")
.addEventListener("click", function () {
setActiveWidget(null);
if (!this.classList.contains("active")) {
setActiveWidget("distance");
} else {
setActiveButton(null);
document
.getElementById("areaButton")
setActiveWidget("area");
} else {
function setActiveWidget(type) {
switch (type) {
case "distance":
activeWidget = new DistanceMeasurement2D({
view: view
// skip the initial 'new measurement' button
activeWidget.viewModel.start();
view.ui.add(activeWidget, "top-right");
setActiveButton(document.getElementById("distanceButton"));
break;
case "area":
activeWidget = new AreaMeasurement2D({
view: view
setActiveButton(document.getElementById("areaButton"));
break;
case null:
if (activeWidget) {
view.ui.remove(activeWidget);
activeWidget.destroy();
activeWidget = null;
break;
function setActiveButton(selectedButton) {
// focus the view to activate keyboard shortcuts for sketching
view.focus();
let elements = document.getElementsByClassName("active");
for (let i = 0; i < elements.length; i++) {
elements[i].classList.remove("active");
if (selectedButton) {
selectedButton.classList.add("active");
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="topbar">
<button
class="action-button esri-icon-measure-line"
id="distanceButton"
type="button"
title="Measure distance between two or more points"
></button>
<button
class="action-button esri-icon-measure-area"
id="areaButton"
type="button"
title="Measure area"
></button>
</div>
</body>
</html>
imritanshu
New Contributor III
2D distance measurement is only supported in MapView. You are using Sceneview.
Also declare activeWidget variable. Your code throws error as there is no declaration of activeWidget on first time. so assign it like below before you are creating view.
you can make use of below sample.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-measurement-3d
let activeWidget = null;
Noah-Sager
@imritanshu is correct in that you are mixing 2D-specific widgets with a 3D SceneView sample. Most widgets work in both 2D and 3D, but not all.
https://developers.arcgis.com/javascript/latest/maps-and-views/
Here is a 2D example of the measurement widgets working with the BasemapGallery widget:
https://codepen.io/noash/pen/dygjwMq?editors=1000
RachelGomez
New Contributor II
To fix the issue with the Measurement widget not working when combined with the Basemap Gallery widget:
Add the missing parts of the code: Include the necessary dependencies and event listeners for the Measurement widget.
Ensure that the setActiveWidget function is properly implemented and called when the measurement buttons are clicked.
Make sure to call the newMeasurement() method on the active widget to initialize a new measurement.
Verify that the setActiveButton function correctly sets the active button by adding and removing the "active" class.
By following these steps, the Measurement widget should function properly alongside the Basemap Gallery widget.
Regards,
Rachel Gomez
