Pan controls ArcGIS4
532
12
03-25-2024 05:04 AM
azy141
New Contributor II
Hi I am looking to add pan controls in the form of arrows to an ArcGIS4 JS map but have been struggling to find the specific api to allow me to do this.
I was wondering if anyone had any input on how I could go about doing this?
Thank you
Egge-Jan_Pollé
MVP Regular Contributor
Hi @azy141,
Can you please explain why you would want to add pan controls to your ArcGIS4 JS map? The reason I ask this, is because I think it is not necessary at all to add such controls to the user interface.
It is quite easy to pan the map - grabbing it with a left mouse click, using the arrow keys on your keyboard or just with your fingers on a mobile device.
So, the map is 'panable' by default. There is no need to add controls to activate a pan modus.
What is your opinion about this?
Cheers,
Egge-Jan
azy141
New Contributor II
I was given this assignment as we are looking at building controls that are easier to use for accessibility reasons.
Egge-Jan_Pollé
I think you will have to add your own buttons to the map, or actually to the view.ui, with a function to move the center of the map an X number of units to the N/E/S/W when the respective button is clicked.
I have never added pan buttons to the ui myself, but for some inspiration you may have a look at this example, where I do add a custom 'previous extent' and 'next extent' button to the user interface:
ArcGIS Maps SDK for JavaScript example: Previous a... - Esri Community
HTH,
Egge-Jan
Paco
Hi.   I would assume you could just add some new html elements and change the MapView (view) by an x,y distance on each click.
Here I added custom zoom in/out buttons in a similar way-
document.getElementById("zoominbtn").addEventListener('click', function(){
  console.log("zoom in")
  var n= view.zoom + 1;
  view.zoom = n
document.getElementById("zoomoutbtn").addEventListener('click', function(){
  console.log("zoom out")
  var n= view.zoom - 1;
  view.zoom = n
ReneRubalcava
Frequent Contributor II
There is a DirectionalPad widget, it's not in the corners though, not sure if that would meet your needs
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-DirectionalPad.html
azy141
New Contributor II
This is perfect thank you
Egge-Jan_Pollé
Hi @ReneRubalcava,
Cool. Didn't know about this little widget. I did quickly create a small sample to test it (see code below) and it works fine. I do like this little compass indicating the orientation of the map (when not 0), allowing you to reset the map orientation (to 0).
Of course I cannot speak for the original poster, but I think this offers most of the functionality requested.
Here is my little sample:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript with UK data - DirectionalPad</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/css/main.css">
  <script src="https://js.arcgis.com/4.29/"></script>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      require([
        "esri/Map",
        "esri/geometry/Point",
        "esri/views/MapView",
        "esri/widgets/DirectionalPad"
      ], function(Map, Point, MapView, DirectionalPad) {
      var map = new Map({
        basemap: {
          portalItem: {
            // GB Cartographic Local Names, hosted by EsriUKContent, see: https://www.arcgis.com/home/item.html?id=5b9d5ac7e17f402a9111f1ca2c22bf56
      var view = new MapView({
        spatialReference: 27700,
        container: "viewDiv",
        map: map,
        center: new Point({x: 500000, y: 500000, spatialReference: 27700}),
        zoom: 5
      const directionalPad = new DirectionalPad({
        view: view
      view.ui.add(directionalPad, "bottom-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Cheers,
Egge-Jan
azy141
New Contributor II
Do you know how I could go about overriding the icons used in this d pad?
MatthewDriscoll
ESRI Icons
        view: view
        icon: "esri-icon-handle-horizontal",
