<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{ margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); var map; function init() { var ext = new esri.geometry.Extent({"xmin":-17878954,"ymin":-2368856,"xmax":11003235,"ymax":12170078,"spatialReference":{"wkid":102100}}); map = new esri.Map("map",{ extent: ext, wrapAround180: true }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer"); map.addLayer(basemap); // polygon JSON // coordinates are in wgs84 so wkid should be 4326, not 102100 var geom = {"rings": [[[-73.7104093,40.54816076],[-73.7519722,40.5871111],[-73.7601326,40.61371559],[-73.7615556,40.8149722],[-73.7562433,40.8320452],[-73.7265199,40.86482226],[-73.6309606,40.8962101],[-73.5906812,40.90843197],[-73.5679025,40.91454289],[-73.3965069,40.9539866],[-71.9822949,41.2742658],[-71.85812147,41.07093545],[-71.85784367,41.0701021],[-71.8675662,41.0606577],[-71.8772889,41.05565774],[-71.91034587,41.04371326],[-72.044796,40.99537948],[-72.39814118,40.8689892],[-72.4800884,40.8420448],[-72.5287016,40.8267668],[-73.0403879,40.6720437],[-73.04316579,40.67121038],[-73.0576108,40.66732155],[-73.1362248,40.6473219],[-73.20219949,40.6340722],[-73.7104093,40.54816076],[-73.7104093,40.54816076]]],"spatialReference": {"wkid": 4326} }; console.log("geom is: ", geom); dojo.connect(map, "onLoad", function() { dojo.connect(dijit.byId("map"), "resize", map, map.resize); // create a polygon object from JSON var wgs84 = new esri.geometry.Polygon(geom); // convert wgs84 polygon to web mercator var webMercator = esri.geometry.geographicToWebMercator(wgs84); // create a graphic var graphic = new esri.Graphic(webMercator, new esri.symbol.SimpleFillSymbol()); // add it to the map map.graphics.add(graphic); // zoom to the graphic map.setExtent(esri.graphicsExtent(map.graphics.graphics), true); console.log("added and zoomed to polygon"); }); } dojo.ready(init); </script> </head> <body class="tundra"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"> </div> </div> </body> </html>
It' WORK to me THANK YOU very much
