PopUp moves based on window Scroll Bar
3249
9
11-25-2016 10:36 PM
CoryJorgensen
New Contributor II
I have a map inside a div with some graphic positions added to the map.  When I click on a freature, it activates the popup.  My div is part of multiple divs on the page, and if I scroll the page, the popup will scroll the map it seems the difference of the map location and the scroll of the window.  If my browser window is scrolled to the top, the popup is placed in the right spot on the map, but if I scroll the window down and move my map, the popup displaces the map the distance I have scrolled.  Is there a way to stop this?
Tags (1)
AdrianWelsh
MVP Honored Contributor
Cory,
Maybe it would be helpful if you post your segment of code that shows the popup?
CoryJorgensen
New Contributor II
Please go here and view how this is working:
https://www.permittrax.com/Citizen/Web_Public/CitizenConn_Main.aspx?R=a0Xg9xaO7RPcvJfQ3GtMzn1k%2bLBz...
This is where I have developed the map.  If you click on a marker on the map, it will show the box up at the top right.  But, if you scroll the page a little so it is centered on the screen, then click on it.  You will see that it moves the map and the marker is moved off the map.
AdrianWelsh
Wow, that is crazy. I haven't seen that before....
Can you post the code you used for writing this? (I do not know how to fix this but surely someone here has experienced this...)
CoryJorgensen
New Contributor II
Here is a link to a JSFIDDLE that shows the problem.  I re-created my page without all the ASP.NET stuff.  It happens on this page as well.  Just scroll the map up and click on a feature and look where the info window goes.
Edit fiddle - JSFiddle
CoryJorgensen
New Contributor II
This is a scaled down JSFiddle with less HTML and junk, the problem still happens.
CoryJorgensen
New Contributor II
Ok, I have added a new jsfiddle.  This is a very scaled down version of my map and the issue.  When you scroll to the map and then click on a feature, the popup seems to be offset by the scroll.  How can I fix this?
ESRI Map Issue - JSFiddle
LaxmanThapa
New Contributor II
I also has similar problem. @Cory Jorgensen, did you solve this problem. and can you please share your solution.
Kind regards
Laxman
CoryJorgensen
New Contributor II
No, we have not found a solution yet.  I have a developer working on it but it seems to be on the ESRI Javascript side.
LaxmanThapa
New Contributor II
Thanks for the quick reply @Cory Jorgesen. Can you please share your solution when you fix it.
