PopupMobile and Bootstrap Nav
2110
10-06-2015 09:38 AM
DavidColey
Does anyone have any ideas on how to use the popupMobile and a bootstrap navbar-fixed-top together?  No matter what I try css-wise for z indexing and/or padding I cannot get the popupMobile's navigation bar to display on top of the bootstrap navbar.  Do I need to get into the helper methods for placement maybe?
Thanks
David
ChrisSmith7
If so, I was able to place it above the nav bar by adding a css override; here's the jsfiddle update:
Bootstrap nav bar; mobile popup ArcGIS - JSFiddle
And the overrides:
.esriMobileInfoView {z-index: 999999 !important;}
.esriMobilePopupInfoView {z-index: 999999 !important;}
.esriMobileNavigationBar {z-index: 999999 !important;}
Hope I understood your issue correctly!
ChrisSmith7
Not sure if I'm visualizing this correctly - is the problem exemplified in this jsfiddle I created?
ChrisSmith7
And the overrides:
DavidColey
That's exactly it Chris, thanks!  It was driving me nuts. My z-index was too low (108 - based on WAB) and I was missing the .esriMobilePopupInfoView class.  I now have:
.esriMobileInfoView , .esriMobilePopupInfoView, .esriMobileNavigationBar {
