I have a mapservice that has 3 layers and each layer has sublayers. I am using mapImageLayer to call popups with the properties sublayers and popupTemplate as displayed below:
var displayLayer = new MapImageLayer({
url: "RESTURL/endpoints",
sublayers: [{
title: "Gas Main",
popupTemplate: {
title: "Gas Main",
content: [{
type: "fields",
fieldInfos: [
{fieldName: "INSTALLDATE", visible: true, label: "Install Date", format: {dateFormat: "short-date"}},
{fieldName: "SUBTYPECD", visible: true, label: "Type"}
The layers structure is:
Layer1 has index 0. Layer1 has two subLayers - sublayer1 with index 1 and sublayer2 with index 2.
Layer 2 has index 3.
I am using layerlist widget. When I have sublayers in the MapImageLayer, the layerlist displays all the layers at once without honoring the sublayers.
But when I do not have "sublayers" property in my MapImageLayer, the layerlist displays layers fine honoring the sublayers. I do not want to use feature layers just to make popups.
Any ideas on how to reconcile popup and layerlist widget.
