Ken, Thanks for taking a look.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>HAS javascript api 4.13</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.13/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.13/"></script>
<style>
html,
body,
#viewDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
#optionsDiv {
background-color: white;
color: black;
padding: 6px;
max-width: 400px;
</style>
<script>
//let buildPopupContent; // fn used later to build popup content.
require([
"esri/Map",
"esri/Graphic",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/PopupTemplate",
"esri/geometry/Polygon",
"esri/geometry/Point",
"esri/geometry/Geometry"
], function(Map, Graphic, MapView, FeatureLayer, PopupTemplate, Polygon, Point, Geometry, webMercatorUtils) {
let tier_FLayer = new FeatureLayer({
url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/9",
outFields: ["*"]
let IAH_Elev_FLayer = new FeatureLayer({
url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/7",
outFields: ["*"]
IAH_Elev_FLayer.visible = false;
let EFD_HOU_Elev_FLayer = new FeatureLayer({
url: "http://10.88.22.95:6080/arcgis/rest/services/HAS/HAS_wm/MapServer/8",
outFields: ["*"],
EFD_HOU_Elev_FLayer.visible = false;
let map = new Map({
basemap: "streets"
,layers: [tier_FLayer, IAH_Elev_FLayer, EFD_HOU_Elev_FLayer]
let view = new MapView({
container: "viewDiv",
map: map,
center: [-95.4, 29.80],
zoom: 11,
popup: {
autoOpenEnabled: false,
dockEnabled: true,
dockOptions: {
// dock popup at bottom-right side of view
buttonEnabled: false,
breakpoint: false,
position: "top-right"
//create graphic for mouse point click
let pointGraphic = new Graphic({
symbol: {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: [0, 0, 139],
outline: {
color: [255, 255, 255],
width: 1.0
tier_FLayer.load().then(function() {
tier_FLayer.popupTemplate = popupTemplate;
IAH_Elev_FLayer.load().then(function() {
IAH_Elev_FLayer.popupTemplate = popupTemplate;
EFD_HOU_Elev_FLayer.load().then(function() {
EFD_HOU_Elev_FLayer.popupTemplate = popupTemplate;
let popupTemplate = {
title: "Airport Tier: {Tier}",
content:
buildPopupContent
// When the feature is clicked, this function is called. The feature is passed into the function. https://developers.arcgis.com/javascript/latest/sample-code/popuptemplate-function/index.html
function buildPopupContent (feature) {
console.log("feature type = " + feature.graphic.geometry.type); // ERROR: Unable to get property 'type' of undefined or null reference
console.log("centroid x " + feature.graphic.geometry.centroid.x); // ERROR: Unable to get property 'centroid' of undefined or null reference
console.log("extent center x = " + feature.graphic.geometry.extent.center.x); // ERROR: Unable to get property 'extent' of undefined or null reference
alert("ObjectId= " + feature.graphic.getAttribute("OBJECTID")); // works
alert("area= " + feature.graphic.getAttribute("Shape.area")); // works
alert("length= " + feature.graphic.getAttribute("Shape.len")); // works
alert("GL= " + feature.graphic.attributes.GL); // works
alert("GL= " + feature.graphic.getAttribute("GL")); // works
let pointLatDMS = new DMS(feature.latitude); // feature converted to degree minute second.
let pointLongDMS = new DMS(feature.longitude);
let div = document.createElement("div");
div.innerHTML = "<b>Check values and click submit to send to the FAA website.</b></br></br>" +
"<form action='https://oeaaa.faa.gov/oeaaa/external/gisTools/gisAction.jsp?action=doNoNoticeRequiredTool' target='_blank' method='POST'>" +
"<table border='0' cellpadding='0' cellspacing='0' width='800'>" +
"<tr>" +
"<td width='20%'> Latitude: </td>" +
"<td width='80%'><input type='text' name='latD' id='latD' size='3' maxlength='3' value=" + pointLatDMS.Degree + " tabindex=''> Deg <input type='text' name='latM' id='latM' size='2' maxlength='2' value=" + pointLatDMS.Minute + " tabindex=''> M <input type='text' name='latS' id='latS' size='5' maxlength='5' value=" + pointLatDMS.Second + " tabindex=''> S <select name='latDir' id='latDir' tabindex=''><option value='N'>N</option><option value='S'>S</option></select> </td>" +
"</tr>" +
"<tr>" +
"<td> Longitude: </td>" +
"<td><input type='text' name='longD' id='longD' size='3' maxlength='3' value=" + pointLongDMS.Degree + " tabindex=''> Deg <input type='text' name='longM' id='longM' size='2' maxlength='2' value=" + pointLongDMS.Minute + " tabindex=''> M <input type='text' name='longS' id='longS' size='5' maxlength='5' value=" + pointLongDMS.Second + " tabindex=''> S <select name='longDir' id='longDir' tabindex=''><option value='W'>W</option><option value='E'>E</option></select> </td>" +
"</tr>" +
"<TR>" +
"<TD>Horizontal Datum:</TD>" +
"<TD><select name='datum' id='datum' tabindex=''><option value='NAD83'>NAD83</option><option value='NAD27' selected >NAD27</option></select></TD>" +
"</TR>" +
"<TR>" +
"<TD>Site Elevation (SE):</TD>" +
"<TD><input type='text' name='siteElevation' id='siteElevation' size='5' maxlength='5' value=" + feature.graphic.attributes.GL + " tabindex=''> (nearest foot) </TD>" +
"</TR>" +
"<TR>" +
"<TD>Structure Height (AGL):</TD>" +
"<TD><input type='text' name='structureHeight' id='structureHeight' size='5' maxlength='5' value='222' tabindex=''> (nearest foot)</TD>" +
"</TR>" +
"<TR>" +
"<TD>Airspace Elevation (AGL):</TD>" +
"<TD><input type='text' name='airspaceElevationAGL' id='airspaceElevationAGL' size='5' maxlength='5' value='444'></TD>" +
"</TR>" +
"<TR>" +
"<TD>Airspace Elevation (AMSL):</TD>" +
"<TD><input type='text' name='airspaceElevationAMSL' id='airspaceElevationAMSL' size='5' maxlength='5' value='555'></TD>" +
"</TR>" +
"<TR>" +
"<TD>Maximum Building Height:</TD>" +
"<TD><input type='text' name='maxBldgHeight' id='maxBldgHeight' size='5' maxlength='5' value='350'></TD>" +
"</TR>" +
"<TR>" +
"<TD>Airport Tier:</TD>" +
"<TD><input type='text' name='airportTier' id='airportTier' size='20' maxlength='20' value=" + feature.graphic.attributes.Tier + "></TD>" +
"</TR>" +
"<TR>" +
"<TD >Traverseway:</TD>" +
"<TD ><select name='traverseway' id='traverseway' tabindex=''><option value='NO'>No Traverseway</option><option value='IH'>Interstate Highway</option><option value='OT'>Other Traverseway</option><option value='PR'>Private Road</option><option value='PH'>Public Roadway</option><option value='RR'>Railroad</option><option value='WW'>Waterway</option></select></TD>" +
"</TR>" +
"<TR>" +
"<TD>Is structure on airport:</TD>" +
"<TD><select name='onAirport' id='onAirport' tabindex=''><option value='false'>No</option><option value='true' selected >Yes</option></select></TD>" +
"</TR>" +
"<TR>" +
"<td> </td>" +
"<input type='submit' value='Submit to FAA Website'>" +
"</TR>" +
"</table> " +
"</form>"
return div;
}; // end function buildPopupContent (feature)
// Constructor function for DMS objects. https://www.w3schools.com/js/tryit.asp?filename=tryjs_object_constructor
function DMS(coordInMeters) {
this.Degree = "11";
this.Minute = "22";
this.Second = "33";
// To do: convert to degree minute secons
// How to Convert Decimal Degrees to DMS
// 1.For the degrees use the whole number part of the decimal.
// 2.For the minutes multiply the remaining decimal by 60. Use the whole number part of the answer as minutes.
// 3.For the seconds multiply the new remaining decimal by 60
// Workflow
// User will click on the Airport Tiers polygon layer.
// A point symbol is added to the map.
// Depending on which Airport is clicked on (HOU,IAH,EFD),
// the corresponding Airport Elevation layer will be queried.
// Elevation info results will populate the popup.
view.on("click", function(event) {
view.graphics.remove(pointGraphic);
//view.popup.remove();
// query Tiers layer.
queryFeatures_Tiers(event);
function queryFeatures_Tiers(screenPoint) {
// Converts the given screen point to a map point. This mapPoint is in the units of the map (meters).
const mapPoint = view.toMap(screenPoint);
tier_FLayer
.queryFeatures({
geometry: mapPoint,
spatialRelationship: "intersects",
returnGeometry: false,
outFields: ["*"]
.then(function(featureSet) {
// Note: This function isn't executed when no Tier is returned.
// set graphic location to mouse pointer and add to mapview
pointGraphic.geometry = mapPoint;
view.graphics.add(pointGraphic);
//const graphics = results.features;
let strTier = featureSet.features[0].attributes["Tier"];
//alert(strTier);
// Check user clicked on a Tier polygon
// "Hobby", "Ellington", "GBIA"
if (strTier.indexOf("GBIA") > -1) {
queryFeatures_IAH(mapPoint);
} else if (strTier.indexOf("Hobby") > -1) {
queryFeatures_EFD_HOU(mapPoint);
} else if (strTier.indexOf("Ellington") > -1) {
} else {
// This is never called.
alert("Please click on one of the airports.")
} // end queryFeatures_Tiers()
function queryFeatures_IAH(mapPoint) {
//const point = view.toMap(screenPoint);
IAH_Elev_FLayer
.queryFeatures({
geometry: mapPoint,
outFields: ["*"]
// open popup of query result
view.popup.open({
features: featureSet.features,
featureMenuOpen: true
} // end queryFeatures_IAH()
function queryFeatures_EFD_HOU(mapPoint) {
EFD_HOU_Elev_FLayer
.queryFeatures({
geometry: mapPoint,
outFields: ["*"]
view.popup.open({
} // end queryFeatures_EFD_HOU()
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
