Print Task: cannot read property of 'query' of undefined
6574
5
02-16-2015 08:58 PM
davidrenz
I am trying to wire up some print functionality on an app that I am building.
I basically just copied the code from the JSAPI samples page ... just to get a sense of how it works,
When I click on the "Print" button, it heads off like the samples do, but I get the following error:
js.arcgis.com/3.12/esri/tasks/Geoprocessor.js?1424148233374:14 Uncaught TypeError: Cannot read property 'query' of undefined
I am not sure how to resolve this, it is the first time I have used the 10.2 print task.
I have also tried to publish my own templates as a print task and that is getting the same error.
Could someone point me in the right direction on this?
thx
David
Code is below:
        doPrint: function() {
            console.log("In the startup for print!");
            //esriConfig.defaults.io.alwaysUseProxy = false;
            //esriConfig.defaults.io.proxyUrl = "";
            // get print templates from the export web map task
            var printInfo = esriRequest({
                "url": this.printUrl,
                "content": { "f": "json" }
            printInfo.then(this.handlePrintInfo, this.handleError);
        handlePrintInfo: function (resp) {
            var layoutTemplate, templateNames, mapOnlyIndex, templates;
            layoutTemplate = arrayUtils.filter(resp.parameters, function (param, idx) {
                return param.name === "Layout_Template";
            if (layoutTemplate.length === 0) {
                console.log("print service parameters name for templates must be \"Layout_Template\"");
                return;
            templateNames = layoutTemplate[0].choiceList;
            // remove the MAP_ONLY template then add it to the end of the list of templates
            mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
            if (mapOnlyIndex > -1) {
                var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
                templateNames.push(mapOnly);
            // create a print template for each choice
            templates = arrayUtils.map(templateNames, function (ch) {
                var plate = new PrintTemplate();
                plate.layout = plate.label = ch;
                plate.preserveScale = true;
                plate.format = "PDF";
                plate.layoutOptions = {
                    "authorText": "Made by:  Esri's JS API Team",
                    "copyrightText": "<copyright info here>",
                    "legendLayers": [],
                    "titleText": "Pool Permits",
                    "scalebarUnit": "Miles"
                return plate;
            // create the print dijit
            var printer = new Print({
                "map": global.MAP,  // ---> yes, I know <sigh!>
                "templates": templates,
                url: this.printUrl
            }, dom.byId("print_button"));
            try {
                printer.startup();
            catch (ex) {
                console.log(ex.message);
            printer.on('print-start', function () {
                console.log('The print operation has started');
            printer.on('print-complete', function (evt) {
                console.log('The url to the print image is : ' + evt.result.url);
ChrisSergent
Regular Contributor III
Hopefully a working sample will help you. I'm not sure on yours, but I based my working code on Esri's print task sample too. I have a working sample that I built off of our own web services here: Print a Map
Click the Hammer
Click the Printer
And then you can print from there
The source code is here: JS Bin - Collaborative JavaScript Debugging
davidrenz
I could really use a hand on this.
If someone could give me a hand, I would totally appreciate it.
When I run the print task and watch it in Fiddler, I get this::
# Result Protocol Host URL Body Caching Content-Type Process Comments Custom
2 304 HTTP www.currymap.org /arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task?f=json 0 private, must-revalidate, max-age=0 chrome:888
This is the error I am getting: --> it means nothing to me except that it keeps pointing back to the Geoprocessor.js file. Could this be a permissions or config issue?
Geoprocessor.js?1424320198202:14
m.execute  init.js:717
y._createWrappers.n.forEach.b.(anonymous function)  PrintTask.js?1424320198202:9
s.execute   Print.js?1424320198202:7
f.printMap  Print.js?1424320198202:8
(anonymous function)   init.js:177
g.hitch_   MenuBase.js?1424320198202:8
k.onItemClick_   MenuBase.js?1424320198202:4
(anonymous function)   init.js:220
ChrisSergent
Click the Hammer
Click the Printer
davidrenz
hmmm .... your code worked with my map services and print service. cool!
Well, I guess I will use your stuff on this. I am not sure why the ESRI example code is not working with it, but whatever.
thx Chris!
davidrenz
Chris,
I just wanted to follow up with you and once again thank you for your help.
Your example helped me see what I was NOT doing correctly.
So, thanks for taking the time to help me out .. it is very much appreciated.
thx.
David
ChrisSergent
Always happy when I get to help someone on here. I receive a lot of help myself. Glad it helped.
