Query a Portal using PortalQueryParams with a filter containing wildcards in tags
232
a month ago
Dirk_Vandervoort
I am interacting with my portal in js code. I wish to query the portal for tagged content using wildcard searches in my query filter.
Code:
const queryParams = new PortalQueryParams({
    filter: 'orgid:MyOrgID AND tags:"TES*"',
    num: 100
portal.queryItems(queryParams).then(function(results){
    // no results are returned
    // we expect results to have tags like TEST, TESTER, TESTING, etc.
I've tried an escape character (\*) and different wildcard characters (*, %, #, etc.) with no success.
I'm missing something obvious. Again. TIA.
AndreV
I think filter only accepts exact values and query is the property you should go with.
https://developers.arcgis.com/javascript/latest/api-reference/esri-portal-PortalQueryParams.html#que...
gdi-hohenlohekreis.de
AndreV
Did you try omitting the quotation marks around TES*?
Dirk_Vandervoort
Without the double-quotes and using either TES\* or TES* returns all content (throttled at 100 in queryParams).
AndreV
