<script type="text/javascript">
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/dom",
"dojo/on",
"esri/tasks/QueryTask",
"esri/tasks/query",
"esri/symbols/SimpleMarkerSymbol",
"esri/InfoTemplate",
"dojo/_base/Color",
"dojo/domReady!"],
function (Map,
ArcGISDynamicMapServiceLayer,
dom,
on,
QueryTask,
Query,
SimpleMarkerSymbol,
InfoTemplate,
Color,
domReady) {
map = new Map("map");
var layer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
map.addLayer(layer);
var pop = dojo.byId('search-text').value;
on(dojo.byId('search-button'), "click", executeQueryTask(pop));
//initialize query task
queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
//initialize query
query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["CITY_NAME", "STATE_NAME", "POP1990"];
//initialize InfoTemplate
infoTemplate = new InfoTemplate("${CITY_NAME}", "Name : ${CITY_NAME}<br/> State : ${STATE_NAME}<br />Population : ${POP1990}");
//create symbol for selected features
symbol = new SimpleMarkerSymbol();
symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
symbol.setColor(new Color([255, 255, 0, 0.5]));
function executeQueryTask(population) {
//set query based on what user typed in for population;
query.where = "POP1990 >"+ population;
//execute query
queryTask.execute(query, showResults);
function showResults(featureSet) {
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
</script>
Solved! Go to Solution.
You title should be in the body of the message, it is far too long and not searchable. Use appropriate tags to facilitate searching as well
Ia,
In your code you never init a var called query. You have the proper require and the proper require alias for Query but you never var query in your code.
See line 24 on the code below.
require([
"esri/map",
"dojo/dom",
"dojo/on",
"esri/tasks/query",
"dojo/_base/Color",
"dojo/domReady!"],
function (Map,
dom,
on,
QueryTask,
Query,
SimpleMarkerSymbol,
InfoTemplate,
Color,
domReady) {
var query, queryTask, infoTemplate, symbol;
//initialize query
symbol.setSize(10);
//execute query
</script>
