In your code you never init a var called query. You have the proper require and the proper require alias for Query but you never var query in your code.
See line 24 on the code below.
<script type="text/javascript">
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"dojo/dom",
"dojo/on",
"esri/tasks/QueryTask",
"esri/tasks/query",
"esri/symbols/SimpleMarkerSymbol",
"esri/InfoTemplate",
"dojo/_base/Color",
"dojo/domReady!"],
function (Map,
ArcGISDynamicMapServiceLayer,
dom,
on,
QueryTask,
Query,
SimpleMarkerSymbol,
InfoTemplate,
Color,
domReady) {
map = new Map("map");
var query, queryTask, infoTemplate, symbol;
var layer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
map.addLayer(layer);
var pop = dojo.byId('search-text').value;
on(dojo.byId('search-button'), "click", executeQueryTask(pop));
//initialize query task
queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...");
//initialize query
query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["CITY_NAME", "STATE_NAME", "POP1990"];
//initialize InfoTemplate
infoTemplate = new InfoTemplate("${CITY_NAME}", "Name : ${CITY_NAME}<br/> State : ${STATE_NAME}<br />Population : ${POP1990}");
//create symbol for selected features
symbol = new SimpleMarkerSymbol();
symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
symbol.setColor(new Color([255, 255, 0, 0.5]));
function executeQueryTask(population) {
//set query based on what user typed in for population;
query.where = "POP1990 >"+ population;
//execute query
queryTask.execute(query, showResults);
function showResults(featureSet) {
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
</script>
