I have several layers getting loaded according to the user's rights towards them. Forexample. I have rights to access only to 5 layers out of 10, I will be viewing only 5 layers in my map and not all the layers. So, I dynamically generate it. Now, for search option to be present for every layer, The sources for the search was given from the ajax call. The layers are getting listed in the dropdown perfectly, but when I search in a particular layer or in "ALL" category it is throwing the following error:
init.js:199 Error: Target must be an event emitter(…) "Error: Target must be an event emitter
var searchParams = [];
$.ajax({
type: "POST",
url: "WebService.asmx/featurelist",
data: "{ 'aData': '" + userid + "'}",
contentType: "application/json; charset=utf-8",
dataType: "json",
success: function (data) {
var myData = JSON.parse(data.d);
var url1 = serviceLoc;
var url2 = "/MapServer/0";
for (var i = 0; i < myData.length; i++) {
searchParams.push({
featureLayer: ""+ finalurl + "",
name: "" + myData[i].Fname + "",
var search = new Search({
map: map,
sources: [],
zoomScale: 5000000,
placeholder : " Object id / Facility No "
}, "shoo");
search.on("load", function () {
var sources = search.sources;
for (var i = 0; i < searchParams.length; i++) {
sources.push({
featureLayer: searchParams[i].featureLayer,
placeholder: "Object ID",
enableLabel: false,
searchFields: ["OBJECTID"],
displayField: "OBJECTID",
supportsPagination: true,
enableSuggestions: true,
enableSuggestionsMenu: true,
suggestionTemplate: "Object ID: ${OBJECTID}",
exactMatch: false,
maxResults: 10,
maxSuggestions: 10,
infoTemplate: new InfoTemplate("Object ID - ${OBJECTID}", "Ipsum Doler")
search.set("sources", sources);
search.startup();
If I hard code every layer on the sources array, it is working fine, but it is not working fine if I load it dynamically. I am clueless now, I request any of you give some solutions for it.
Thanks in advance
